1995 Buick Park Ave. Passenger Door Lock Problem
Suddenly the electric lock on my 95 park ave passenger door won't unlock when i hit the unlock button on the door or the drivers door. i took the door apart thinking it needed lubing possibly on the mechanisms and that didn't help, then i started checking it for electrical problems and found that the plug for the lock side of the lock mechanism has low voltage on it all the time and when i touch it with a test light it makes a relay on the passenger side kick panel click. can anyone guide me as to how to find and correct this problem?
handle inside broke. I got a brass screw from the junk screw can in my tool box
drilled a tiny hole and replaced the finger. That did not fix the entire problem, it
turned out the entire door lock assembly was needed. There are two parts the actuator is cheap 41.00 at autozone. But you must remove the old one that is
riveted on to the main lock assembly the rivets are easily drilled away then the
new actuator can be bolted back on [my way]. Sadly the lock mechanism needed
to also be replaced. Now it works 97% of the time. Sometimes you need to lift
the handle thrice before you get the door open, The inside has never been a problem.
