My 1996 Town and Country Van needs HELP.
I will be driving my van and all of a sudden it will rattle/shake until I let up off my gas for a second. Then it might not do it again for a couple of days, then again it might do it off and on until I get to where I'm going. The feel and sound reminds me of those ridges you drive over in the road that remind you to slow down for a stop ahead. My tires are new and other than that it runs great..
-if not that check your rack and pinion assembly sometimes you can adjust that kind of problems with Yoke lash!
-check rack and pinion, bushings!!!
when you did alignment to the car,
was it 2 wheel
or 4 wheel alignment?
before any alignment mechanic should check all front and rear suspension parts (shocks, springs, tierod ends, ball joints, all the bushings, lower contrl arm, upper contr arm, spindle, steering knuckle,)if any of this part is bad alignment is pointless!!!!!!
did the car was in any accidents before?
check the tires for any type of wear, that can tell you a lot,
I hope is not the SAI this angle is not adjustable and might cause big problems
next time when you're doing alignment tell them to print out your CASTER, CAMBER AND TOE measurments before and after alignment
Did you pull the OBD-II codes?
Problem is ignition (no spark) or no fuel. First have to figure out which one of those two it is.
When I hit a "ridge" in the interstate or over some speed bumbs there is thud, it feels like the dirvers side front wheel bottoms out. Mine is a 1994 Town and Country with 188000 miles and the 3.8L V 6.
So far I have changed....
The long rack (for a different issue)
Sturts and shocks
CV joints
Had a 4 wheel alignmnet
All the motor mounts (this did not fix the issue, but made a tremendous difference in the way the car behaves, I would recommend this to anyone if you are getting a jerking feeling or shaking when starting off.
Sway bar bushings
Any ideas would be great! Mack29
