Power Steering Failure
lacrossesick
Member Posts: 2
Have anyone had a power steering failure? I purchased a 2007 Buick Lacrosse with 13000 miles on it and I have 69000 on it now. I always had it serviced in a timely manner but I started hearing a whining sound in steering.
The power steering fluid was slowly leaking out of the car. When it was checked by my mechanic he found it leaking from around the pump hose. The pump and hose had to be changed out. GM says this was not a fault from the manufacturer.
I do not want another GM car, ever. I am through with American made cars.
You lose a PS hose and you whine like a little girl? Go ahead and sell it then. When you start blowin motors and grinding up tranny's then you will have something to really moan about.
OH, and thanks for the follow-up. You come on here to whine for sympathy and don't share afterwards. It is expected that you share your results after you come in here sulking. How old are you girls anyway?
Once again, to the peeps with multiple occurrences my condolences.
There should be a reasonable expectation that this hose last over 200K. Many worn out vehicles made it to the junk yard with never having to replace a PS hose. This happening to a new vehicle? Someone needs taking to the woodshed.
I had 09 Malibu that handled very badly and a second problem related to EPS. GM buyback and the lady who bought it tracked it to me somehow. She thinks it handles badly. So it still stumps the mechanics. I had independants check alignment and look it over and they found nothing. But I did learn it had no adjustment for castor and that shop told me that to adjust it is a practice to loosen the subframe/cradle and shift it slightly and re-tighten. I had noted that the forward rubber mount doughnuts appeared different left to right. That is one side appeared to be more forward than the other which would mean the amount of rubber was not equally distributed around the bolt and mounting surface. That would equate to different resilient actions depending upon the angle that the force was applied. Also the rotating mass of engine and transmission would have a gyroscopic action. And if not exactly at right angles to where the vehicle is when going straight, it could have an influence.
With the cost of that repair, I strongly suspect that your vehicle is one that requires dropping the cradle to remove the rack and pinion. And they shifted the cradle to a better/straighter position, without intent. Then aligned.
This is just theory, but feel it would have been something worth checking on that Malibu, afterall they were out of ideas.
