Calling Los Angeles-based car shoppers: Have you recently traded in (or plan to trade in) a car with negative equity (i.e. the amount you owe on your auto loan is greater than the car's value)? A reporter would like to speak with you; please reach out to PR@Edmunds.com by 11/6 for details.
2009 MDX programmed info mysteriously erased??
Hi, i have an '09 MDX purchased a few months ago, only have a few hundred miles on it but had programmed maybe a dozen addresses, XM presets, voice-activated phone numbers to dial and changed screen/program settings and preferences, and added a PIN.
Started car today after not having driven it for a few weeks and all of this was gone - only things remaining were home address (but without phone #) and bluetooth link to my phone - everything else was gone!
Any idea what would cause this?? I was using same key I normally use, battery hadn't died/no other issues w the car. What could have caused the whole system to reset?
I've had this happen a two times on my 09 Tech/Ent as well. In my case, for some random reason, the car did not properly detect that driver 1 was entering the car. In my case, I noticed because all my radio station presets were missing.
No problem. Turn off the car, and re-enter. Make sure on the little screen it says "Welcome" AND "Driver 1".
Hope that helps if it's similar to your case.
