Sprinter ABS light, traction control light on
sprinterguru
Member Posts: 24
Does your Sprinter have an ABS light or Traction control light on intermittently and does the engine derate the power?
1. Check your wheel speed sensors, rough roads can cause the speed sensors to back out away from the tone wheel. Reseat them by tapping them back in until they stop against the tone ring. They will be bumped out slightly after a few miles to the correct depth by movement in the bearing.
2. Check your brake light switch, located at the top of the brake pedal lever. if it is stuck on or intermittently sticking on the truck thinks you are trying to slow down while you have your foot on the gas. Computers don;t like these kind of messages so it thinks you have a problem. Click, on goes the light.
3. Check your high mount brake light, we have seen shorts in this light that can cause this same issue.
Roy
Roy
A light on your dash will come on when your fuel filter is starting to plug up. You will also experience reduced power on acceleration if the filter is starting to plug. Good idea to change the filter now with 45k on it, not a problem to wait another 600-800 miles. I hope this helps.
