-September 2024 Special Lease Deals-
Recently got a 2005 LS and need some guidance
phessional
Member Posts: 1
So I decided to this beautiful car but bought it May and had to fix a few things already. First it was the Dual Valve for the A/C and it ran me about $500. Then it was the Throttle sensor which ran me about $200. Now it stutters when driving and it has stalled on me a few times. I thought it was the transmission because sometimes I feel a hard shift between 2nd and 3rd but when I took it to the shop the mechanic said it needs a tune-up and will also need to replace the coils which will run me about $1,000. I have never bought from a dealership and this was my first time so I forgot to ask for a carfax, would anyone who has unlimited access be able to help me see if this car has been involved in something the dealership didn't tell me. My VIN is 1LNHM86SX54614749. or if anyone has had similar problems with this car be able to tell me if coils are necessary. It has 60,000k on it. Any advice will be appreciated, thanks.
My '05 V6 was missing, I just replaced the three on the driver side, figuring 50/50 chance of solving the problem, and the car runs great now. If it's missing bad, new coils will definiterly help the mileage.
or you could simply bring me the car and i'll do it for the same price they are going to charge you, and but a huge amount of cash in MY pocket.
1.) Change fuel filter about every 15K. The filter is small and probably plugs
quickly. Easy to change - left front wheel well - remove the wheel, remove the backside black plastic well liner and you'll need an 8mm 1/4" socket & wrench and a flat screwdriver. Carefully remove and reuse the old plastic clips - as the Motorcraft doesn't usually come with new ones. Fram does.
2.) I decided to follow the 30K tranny flush interval and that is the ONLY maintenance I let my dealer do on my car. I do the power flush without filter change (they can't change it so don't let them sell you that.) They need to put an additive also - make sure that they do.
3.) I've used Mobil 1 oil and change every 5K - engine looks brand new inside.
4.) I've found that when I power wash the engine - this is when I have coil problems. I have an OBD II scanner and it always tells me the specific coil that is shorting out. I have also found that these coils and water do not get along. I think the same is the case for if there is oil accumulating in the plug well. So -- I have learned to limit the driving once a coil starts a misfire and check which has moisture in it. If you dry out the plug well (you can roll up a paper towel and dry it out easily.) If the coil in question is on the passenger side for the V6 - swap out one from the driver's side - in case the coil really did die. I've run into the same issue with my 2003 Towncar - so i try to be cautious when cleaning the engines. My guess is - if you aren't cleaning your engine that it is probably an oil build-up in the plug well.
5.) The 2nd to 3rd gear shift is very complex. The LS 5-speed auto - actually has to shift TWICE between 2nd and 3rd. That is why it is sometimes rough. The tranny had 3 gears and an over drive. 1st is 1st. 2nd is 1st + overdrive. 3rd is 2nd gear. 4th is 3rd gear and 5th is 3rd plus overdrive. So - for the 2-3 shift it has to first remove overdrive from 1st and then change into 2nd gear.
6.) Cabin air filter needs changed every 15K at a minimum, too. Easy to change and the dirty one will make you wonder how air got in the cabin at all!
Probably the biggest issues now - are that the front suspension bushings are starting to get loud over bumps. I'm also concerned about the longevity of the ball joints. My steering wheel cruise buttons are losing the black paint in spots and my right arm rest has a small crack. Oh - and the steering wheel retraction chatter does get annoying! I wish the heated seats didn't cycle for just 10 minutes, too. I think several of these issues were fixed in 2003 - as a result of the feedback from websites such as this. It was cool to be a part of that whole process.
I have 123,000 miles on my car and really have been thrilled at the quality of this car. Besides the original battery - I haven't ever recharged or messed with the A/C and it blows super cold and strong - all summer long.
I regularly get 25-27 mpg on highway trips and rarely below 22 mpg with mixed driving.
My 2003 Town Car with real-wheel drive does fantastic. I didn't even have to put extra weight in the trunk the 2 winters that I've driven with it.
Nothing went like my early 90's FWD Continentals with snow tires - I could go just about anywhere with those. Too bad those cars were built so poorly - they were great vehicles for comfort/space, etc.
