Nissan Pathfinder Heat Is Way Too Hot!
I've had the dealer fix this 2 x now, but it still is the same. When i turn the heat on, especially after it's been running for a while, the heat is just way to hot. The temp gauge will be at 62 degrees, but it will feel like its 90! the only way to make it cooler, is to turn the gauge to 60. and then it starts to fluctuate, so i'm constantly having to change between 60-70 degrees. Its very very annoying! anyone have a similar issue?
