Chevrolet Uplander Transmission Issues
uplanderguy
Member Posts: 17,332
in Chevrolet
Since new, my van has sporadically had a few-second lag between reverse and drive when cold, but of course was told that this was 'normal operating procedure'. At 59K miles, I had the trans serviced only as a maintenance item. The dealer flushes, not only drains and refills, the fluid. Within a couple months, I had to add about half a pint of ATF, and noticed that every once in a while, pulling away from a stop, I got a sensation like someone had bumped me from behind. Also, lately, if the van has been driven on the highway for a number of miles, then you get off and drive in stop-and-go traffic, upshifts all of a sudden become hard. If you then stop for gas, or whatever, turning the car off, then back on, the shifting is as smooth as butter, just like when you start in the morning. This indicates to me it's something electronic, but I'm not getting a Service Engine Soon light on. Anybody else having this?
Bill
Bill
I realized it is something electronic as well since when I turn off the engine and starting again it disappears.
any advise?
Another symptom was that the trans would whine when it was doing the hard upshift thing...
Hope this helps...
Bill
Since you replaced the battery, you powered everything down b/c it had no juice...maybe it reset the PCM?
I'm no help here...
BTW - to answer your question (sorry so late) a PCS replacement is about $ 700-800 repair if that's what it turns out to be...
We were having a problem with the eject button of our DVD player in our Saturn Relay. It was suggested that pulling the fuse for the player would reset the player and correct the problem. I couldn't find the fuse panel, however the battery needed to be replaced with the same result. The DVD player seems to be functioning properly again.
Also... I was told the 4T65-E transmission in many GM FWD vehicles tend to run hot. Too hot. Especially during hot temp day and stuck within stop/go traffic - while loaded down. My transmission specialist told me to install an aux transmission cooler - rated to pull 5,000 lbs trailer (for my '09 Montana van). Thus, creating more "cooling" then factory. Cooler transmission (even if van only used as local "run about" vehicle) means longer life in the long run. The transmission cooler I installed is Hayden 1678, and its been working great since day one. re: http://www.bulkpart.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=2&Product_- - - - - - - Code=OC-1678&Category_Code=hayden-transaver
re: http://i178.photobucket.com/albums/w251/Spike99-Pictures/Montana%20Van/AuxTransC- - - - - - ooler-UpperSupport-1.jpg
After you get the transmission fixed (sensor change or rebuilt with new kit), do install an aux transmission cooler as well. The Hayden 1678 for attached 5,000 lbs trailer works great in my wife's van. Especially on "hot blistering" summer days.
Also... Do ask your transmission specialist if the new Dexron VI ATF fluid should be used in your older GM vehicle. My one buddy installed this "much better" ATF fluid in his older GM vehicle and feels it's much better (better then its older ATF fluid). re: http://www.imperialoil.ca/Canada-English/Files/Products_Lubes/IOCAENCVLMOMobil_S- - - - - - - uper_Dexron-VI_ATF.pdf
Hope this helps as well...
Sadly, I think the Uplander and its sibling vans have probably done more to hurt GM's image in owner's minds in the past five years than any single GM product in the twenty years before that. Add to that, that the Pontiac version was discontinued here after only two seasons, and the Saturn after three, and you've got awful resale value to deal with too. I truly cannot remember when GM bailed on a product so quickly as these.
