-September 2024 Special Lease Deals-
After market exhaust and having an O2 sensor issue
crazyjimmy
Member Posts: 3
I put an OBX Exhaust Manifold Headers 02-06 Toyota Camry 2.4L I4 and an ram air system from K&N.
I no longer have a cat converter, however still have both sensors hooked up. I am geting and error that there is something wrong with the cat converter. Short of replacing everything is there anything do?
I have an 2002 camry le 2.4 with auto trans
Either put the cat back or ignore the CE. But the danger in that is having another more serious fault "shadowed" by the ignorance.
Thanks for your great support and by the way only ignorant people use ignorance. That's something to ponder. :shades:
Not sure what state you are in and the smog inspection they'll do, but in my state your vehicle would not pass now. Check your state inspection rules, to help determine the next course of action.
Having a permanent on (and taped) CEL, would mask any other different problems that might turn the light on, so you should probably get an OBD2 reader and check the computer periodically for other codes that computer might have thrown for other different failing conditions.
A constant CEL would result in "ignorance" (not knowing about) of any other "CEL" type problems, maybe more serious problems, that pop up later.
