Crazy Wipers
I own a 2003 accord. Intermittently the wipers will bang into the cowl and pillar when they are used. It does not matter if it is raining or I am just using the washer feature. Can anybody help me out?
Its easy to do your self. Typically there is a cover over a retaining nut. Remove the cover, then nut. Wiggle the arm until the arm comes off the car. They are spring loaded to hold them against the window, you will have to wrestle just a little to keep the arm straight to remove. What you will see is a splined/tapered shaft. Just replace the arm after you readjust the angle. You may need to remove/replace/test a few times until you get the angle correct.
Mrbill
forumn post
This was on a '96.
