Mazda CX-9 Rear Washer
zaxdadzaxdad Member Posts: 2
edited August 2014 in Mazda
Hi All.
I just picked up a used 07 cx9. So far so good. One problem I have is the rear washer appears to be missing. I assume it is in the rear spoiler. Does anyone have any idea how to remove the interior portion? I'm hoping that's where I will find the part.
Thanks for any help.
Zaxdad
  • cericceric Member Posts: 1,092
    The spray nozzle is inside the "hole". Use a flash light, and you will see it.
    Why do you want to remove the spoiler? Is it broken?
  • zaxdadzaxdad Member Posts: 2
    That's what I get for listening to a friend. It works fine. Looks a little weird,but works fine
  • legacygtlegacygt Member Posts: 599
    This car has one of the sloppiest rear washers I've ever seen. Seems like half the fluid ends up running down the window onto the tailgate before the wiper gets over to it. I think they should have put the nozzle on the other side (above the home position for the wiper) so that more of the fluid gets onto the wiper.
