Honda CR-V Door Lock Problem
I posted my problem to an existing discussion but after several days it was clear that that one was dead. My drivers side door in my '04 won't work with the clicker. I've learned it is probably the solenoid type switch inside the door. What I need to know now is how to get the door panel off without a crowbar. Any help is very appreciated. Fixing to sell.
Let me know what can be done to fix this. Meantime if i find any luck i will update you guys.
Can you forward me the soft copy of the manual or the tech center numbers...
That will be great help
2009 Cr v rear passenger door lock loud grinding noise replaced in april and now passenger side front same issue Aug 2014. Drivers side front giving problems - any known issues with door actuators/locks?
