power outlet
The power outlet of my 2010 forester is not working. So I took it to the dealer. They said it is my charger that fries the fuse. Everytime they plug in the charger of my GPS, the fuse blows right a way. But outlet in the glove box works with the same charger. They told me the design of these two power outlet is a little different. The cigar lighter is easy to be damaged. They suggested me to get a charger that's compatible with subaru.
I am curious if anybody is having the similar problem with the power outlet. What charger do you use?
By the way, where is the fuse? Is it hard to replace it by myself?
Unless you try a variety of other units with no problem, there is no way to verify whether it is the unit or the outlet that is the problem.
