Chevrolet Impala Maintenance and Repair
in Chevrolet
i have a 06 chevy impala LT and my first problem is the check engine light would blink off and on then stay on then its start blinking again. Second Problem is an electrical prob every tyme i stepped on tha pedal the lights flicker.Third problem is the engine shakes when i come to a stop but not when im driving. And last problem is everytyme i go to make a right turn or goin in a loop the gas needle starts to drop then when i get bak on a straight away it goes back up. If anybody can tell me how to fix these problems or wut it is i would really appreciate it thank u
MODERATOR /ADMINISTRATOR
Review your vehicle
Gas needle moving could be a loose fuel pump float or bad fuel sensor in the tank.I have a sloshing noise in my tank and i know it's more of a poorly designed gas tank baffle system,it doesn't bother me to much.
If you have age and alot of miles on it you may wish to just change the fuel pump out and make sure you get one with a float on it.i've seen some that don't have it on them and those are the real cheap rebuilt ones.Me...i'd get a new one and be done with it for years to come.
Check engine light has stored a code in the computer,have someone scan it for the error cose(s) to see what's going bad or is bad before it get's worse.Many shops will do a scan for free if they get the repair.
Best of luck to ya.
