New Fuel Pump wiring
gmkengmken Member Posts: 1
I just replaced the fuel pump in my 95 safari. dropped the tank got the new one in but there is a problem.
the wiring doen't connect up form the van to the new pump. in the box the new pump came in is the correct wiring but it didn't say which wires to splice it to on the old connection.
there are the same amount of wires, (4) but the colors are all wrong.
  • mike9897mike9897 Member Posts: 1
    Hello, I have a puzzling problem with my van. It starts hard only when left overnight. In the morning I have to hit the gas and turn it over several times. I just had a full tune-up with cap, rotor, wires, plugs and fuel filter. I also had the fuel injectors replaced. This problem started right after the repairs we done. Any help would be great.
  • davemo1davemo1 Member Posts: 1
    Mike,
    did you ever get this hard start issue resolved? What was the fix? I have similiar issue with my 03 safari. same situation of parts replaced. It cranks for several seconds now before starting.
    Dave
