-September 2024 Special Lease Deals-
2011 535i Tires and Rims
Has anyone else had that same problem with tires and Rims on a 2011 535i this year. I know that potholes have been bad the year but replaced two rims and two different tires. I also had a front and rear alignment. Coast was a mear
$2800, Wheels are 19" Light alloy V-spoke wheels style 331-with all-season run-flat tires
I had the car out for a day, drove different roads to avoid the potholes and the problem is back again; a vibration in the steering wheel and the car drifts a bit, I have to bring the car back in to the dealer again this week.
I contacted BMW customer service. After a week and no call back I contacted them again. I had to pin them down to a time when they would call me call to address the issue. The outcome of course is they they are refusing to do anything for me. I asked to be put in contact with the BMW district manager and they did not know who that is and would not find out (I asked for this info on the first call to CS). I have driven a BMW loaner for a week over the same roads as my own vehicle and I do not have any problems with the rims on the loaner vehicle. I contacted my selling dealer and they have not returned any of my calls.
In the end I will just have to rack this up to a learning experience, which is BMW does not really care about the customer; their customer service is nonexistent. BMW may have other great products but the 2011 535i is a mess of a car.
One item they did fix, I had very active steering. The shop forman went on a drive with me and stated that the steering was normal for a BMW, he did a software update and eliminated the problem. Again, never admitted to the problem and never reviewed it with me but non the less he did the repair.
This car has to go.
A tire wheel combination as suggested above will not degrade the handling of your car at all, however, the ride will improve and your ability to get away with encounters with pot-holes and such will be dramatically improved.
EDIT:
I just configured a set of wheels and tires for your car over on TireRack.com and here's what I came up with:
A set of 17x8 Rial Salerno wheels: $556.00
A set of 245/50 ZR17 Continental Extreme Contact DWS Tires: $660.00
A set of TPMS Tire Valves/Sensors: $212.00
Shipping: $104.40
Total: $1,532.40
It seems that the above solution would be far cheaper than chucking your car and going with something else. Yes, no?
- The overall tire diameter doesn't change
- The new wheel size has the proper inner diameter and offset and such to clear the brake calipers and position the tires (from a lateral perspective) where they're supposed to be. That you'd be downsizing means there's also a pretty good chance the tire/wheel combination will be lighter than the OEM setup, and that will improve both the ride and the handling as a result.
FWIW, for winter tire service folks have been downsizing the wheels on their BMWs for decades (literally), my cars included, and everything operates as it should. In the case of my 5er, it came with 17" wheels and I downsized to 16" wheels for the winter months; the ride was a bit softer, the handling softened a bit (more to do with the narrower winter tires and their ability to bite the pavement than anything else), and the ability to absorb a pot-hole hit grew enormously.
As a suggestion, bluntly inform your service manager you're going to downsize (whether you really plan to or not) and see what he says. There are reports of some service managers claiming such a move will void the warranty (a silly notion), and if he does, ask him to put it in writing. If he’s bold enough to do so, send it to BMW in Woodcliff Lake, NJ; they'll tell you your warranty will stay perfectly intact.
The funny thing with the wheel sizes larger than roughly 17" is that their only functional advantage over smaller wheels are their ability to clear large diameter brakes. The other pseudo advantage to larger wheels it the whole bling-looks thing, something I think you'll gladly do without in exchange for a setup that doesn't constantly get bent.
The question you need to answer is this:
What are the general road conditions in your area, and what is your driving style?
While it's true than some owners have repeated incidents of tire & wheel damage, it's also true that the large majority of owners don't. Also, insurance plans aren't offered at a price that costs the insurance companies $$$.
Only you can determine if the plan offered is right for you, but again, most owners would come out ahead by banking the premium amount. Having said that, a friend of mine with an M3 bought the plan and had a damaged tire replaced with no hassles at all. He damaged the sidewalk by "curbing" the tire on a sharp edge. He's had the car for a year, and so far, he's still behind the curve on payback from the plan.... But, he has 4 more years.
Good luck in whatever you decide...
I have a 2010 328i convertible, a 2007 Z4 Coupe, and my wife has a 2005 Mini convertible.... all with RFT's.
Both the BMW's are equiped with the Sport package (18 inch wheels).
Personally, I have never had a wheel/tire issue, although my wife has replaced 2 RFT's over the years (tire punctures along the sidewall edge).
Even then, it was cheaper to replace 2 RFT's out of pocket...
Still, I recommend looking at your own driving history and environment before deciding. Do you get many flats? Hit a lot of potholes? Unusually bad roads in your area?
Good luck?
My 535 will have the exact 19" wheels that are the subject of an apparent class action over undue cracking issues.
I priced the tires on Tire Rack and they are $415 each, excluding shipping, tax, installation, etc. so I figure that I will have close to $1k on each wheel/tire combo.
I have always come out ahead on extended warranties in the past, so I will roll the dice and enjoy the peace of mind in the meantime. Plus, I got the dealer to knock off $50 (wow) so I'm at $1,200 for the protection.
Hopefully, you will never need the insurance...
Again, may the wheel and tire gods be merciful to you!
Its a known BMW problem that low profile, run flat tires do not have enough sidewalk between the road and the rim. I have this confirmed thru 2 very good BMW mechanics.
Buyers beware.
Further, BMW will not make good on the problem. Make sure you purchase the third party insurance.
"Driving over rough or damaged road surfaces, as well as debris can cause serious damage to wheels, tires, and suspension parts. This is more likely to occur with low-profile tires, which provide less cushioning between the wheel and the road. Be careful to avoid road hazards and reduce your speed, especially if your vehicle is equipped with low-profile tires. Run-flat tires do not come equipped with a spare tire and wheel."
Said another way, while BMW offers a large wheel and low-profile tire package for those whom insist on having their cars equipped accordingly, they also recommend against buying said package. So, while you may want to blame BMW for the wheels and tires you've damaged, I really don't understand your logic for placing the blame anywhere but squarely on your own shoulders.
BMW is no longer the company they were, so they continue to bring cheap china made junk to anyone that will buy it. Its that simple.
I have had no problem with the 2012 Audi A6 low profile tires and all. Oh and did I say much more fun to drive.
Seriously? You sound like someone who knocks a brand for no other reason than you have nothing better to do.
"The problem is not with the buyer of these vehicles it is the automotive company that keeps offering the same cheap product, riding on the coattails of a reputation of days gone by."
Incorrect; the problem is the buyers of these vehicles who don't read the fine print and then when they mess something up they want to find someone to blame for their own screw-up.
"BMW is no longer the company they were, so they continue to bring cheap china made junk to anyone that will buy it. Its that simple."
Where'd you get that little gem? Oh wait, you like make stuff up on the fly. :P
"I have had no problem with the 2012 Audi A6 low profile tires and all. Oh and did I say much more fun to drive."
Most likely an irrelevant comparison. Why? BMW offers not one, not two, but three different "low profile" tire and wheel sizes for the 5-Series, and unless your Audi is equipped with a tire and wheel combination that is as low as the 19" setup on the 5-series, then you're comparing apples-to-oranges. Even if your tires have the same sidewall height, the comparison isn't terribly relevant. Why? Because lots of folks 5-Series cars and 19" wheels have (so far at least) no problems as they've been able (so far at least) to avoid road hazards.
Compared to Germany, our typical roads are trash...they tend to build them with MUCH more depth and a foundation designed to last ages. Ours are much thinner, and with the traffice and freeze/thaw cycles common to lots of the country, ours just plain fall apart quicker. Then, the quality of repairs, when required, just aren't always the best. If you want to complain, complain to the local and national government, and get them to actually spend the fuel tax money on road maintenance rather than other things...or, bite the bullet and pay the fuel costs those in Europe tend to pay...the gas costs about the same, the differences are in the taxes...more money to actually make and maintain decent roads. In the meantime, use higher profile tires...or, pay the consequences.
Regarding the disclaimer which I referenced a few posts back, it only applies to the largest of the wheel options for the 5-Series; it does not apply to the stock setup. Those with more "normal" wheel/tire setups have no more chance of suffering a wheel or tire failure than anybody else.
Regarding the whole RFT thing, I, like many others, feel it was a stillborn idea on BMWs part, and will continue to criticize BMW until they revert to tried and true GFTs.
Just to make sure I'm not confusing your post with that from another, what wheel and tire size are you running?
I think you safety is worth a few phone calls while stuck in LA traffic.
Let me know how you make out.
Silly me, I was looking at the BMW USA web site which indicates the Sport Package of some models of the 5-Series can be had with the following:
- 19" Light alloy Y-spoke wheels style 315-with performance run-flat tires
- 20" Light alloy Double-spoke wheels style 316-with performance run-flat tires
I guess you know better.
"Actually thinking about it the disclaimer that you speak about so often that comes on almost every wheel that BMW sells should come on the sport package option itself."
As far as I know, all Sport Package equipped 5-Series models come with the disclaimer regarding the low profile tires.
I have no doubt that many dealers fail to adequately explain the issues with low-roller tires to potential customers (as few salesfolks wish to do anything negative in the sales process), but we are talking about purchases well above the $50K range here. I know when I spend that kind of coin, I do a bit of research before-hand, so that I know EXACTLY what I am getting in on...
BMW has made it pretty clear that RFT's are its offering, so I really don't have much sympathy for one who purchases a new BMW and then realizes later it came equipped with RFT's and no spare. Like you, I would prefer BMW offer alternative tires (and at lease a place to store a space-saver spare), but the company sees differently. Since they continue to set sales records, especially in difficult economic times, it speaks volumes about how little the "important and significant" issue is to new BMW buyers.
No doubt a low-profile RFT is tougher on a wheel rim than a comparable GFT, but I can take you to a local wheel repair shop that has no shortage of work in repairing rims that were bent running GFT's, so it obviously occurs across the board...RFT's AND GFT's.
To me, the real issue being avoided is our road and highway decline. Everyone wants a smooth road and no potholes, but much fewer are willing to pay the road taxes required to keep our roads in the shape needed. Its an age-old problem.
I think its human nature to want to blame someone else for bad things that happen to us, and in these particular cases, its easier to blame BMW for bent wheels than to accept responsibility for buying a product that needs an extra amount of "attention to detail" when being used in order to avoid damage.
So, the comment another poster wrote about BMW needing to state a warning that BMW wheels may sustain damage on roads that will cause no damage to any other manufacturer's wheels/tires rings hollow for me...
Having been a huge BMW fan and consistent owner for so many years, I must say that I'm very sad about this whole thing. Knowing how conservatively I drive, and where I drive, I still maintain that BMW should be taking responsibility for this problem.
For 10 months, I have been driving a car that shimmies and shakes at certain speeds. It drives me crazy. And I'm paying so much for this lease!
How much longer on the lease?
And the wheel diameter is???
The people at BMW did not warn me of this when purchasing the car.
As I said in an earlier posting. few salespeople wish to discuss ANY negative in making a sale. Does this surprise you? Its shouldn't.
They declined my offer to purchase the tire protection 2 days after the sale when I learned of these issues.
Assuming it was new when you made the purchase, I find that odd. I know folks that have bought BMW/dealer sold wheel/tire protection within 30 days of taking delivery of their new vehicle. I wouldn't blame a manufacturer for a bad dealer action.
If you google “BMW tires” you will see a long list of people who got burned just like I did. Everyone at BMW knows that the tires are defective and for not sharing this info with customers they are showing that they are not a reputable company.
One can "google" just about any other manufacturer and find some gripe that many posts complain about. The fact remains, in your particular case that the vast amount of complaints are on larger diameter wheels, usually 18+".
My wife is refusing to drive the car anymore so I’ll be happy to sell anyone this one but am a reputable business man and will tell you that your life will be hell with the tire issue.
The obvious solution is to install smaller diameter wheels with the correspondingly larger tire size, thereby giving more sidewall rubber. To let such an easily made modification keep you from driving an otherwise upscale car seems a bit odd to me.
Why not give a local wheel/rim shop a call and discuss with them? Ask them if they don't see a wheel size-wheel damage correlation....ie, the larger the wheel, the more bent rims and damaged tires. You may be surprised...
Putting my money where my mouth is, I bought a new car last weekend, a new car which came with 18" wheels and tires with less than 3.5" of sidewall height. Before the new car's engine had cooled in my garage I'd already ordered a set of 17" wheels and tires for it; I installed them yesterday.
Funny thing about the new car, the finance manager of the dealership has the same car and as part of her pitch to get me to buy the tire insurance, she admitted that she'd broken seven wheels in the last eighteen months (not surprising up here in New England). Instead of buying the insurance I bought the above mentioned new set of wheels and tires for less than what the insurance would have run me. My next step will be to sell the OEM set; I figure I can recoup at least eighty percent of my initial outlay for the new wheels and tires. Pretty cheap insurance in my book.
Fortunately, neither car is a daily driver....and, I was aware of the increased possibility of wheel and tire damage. I decided to take the risk, "eyes wide open" knowing the chances were higher of tire related issues, simply because I liked the look on the vehicle. If I do have such an event, one thing I won't be doing is blaming BMW or the tire manufacturer.
Unfortunately, due to budget constraints, roads in all 50 states are going to get much worse before they get better, and I suspect we will see more and more complaints from large wheel diameter owners.
http://www.lead411.com/company_BMW_1168093.html
