Isuzu Rodeo Reduced Power Light Fix
Ok, those of you who are having electrical issued with your rodeo, where the engine stalls, or misses, or you hit a bump and the reduced power light comes on---- here is the simple FIX (the first place you should check) it solved my problem immediately, and hopefully it will yours.
Another person on came up with this solution and has it posted somewhere, but I'm reinforcing this because it fixed my issue.
OK-- on the main wiring bundel which runs from the engine to the computer module(8"x8" light metal box on drivers side near brake fluid reservoir)....on this wiring bundeled together which contains at least 100 wires, there should be a metal bracket which bolts(10 mm bolt)directly onto the engine. This is the ground connection, and the bolt should have a clean contact and bolted tightly on there otherwise it throws the computer off when the car hits a bump or stops.
Check this item first, hopefully it solves your issue.
Brendt
Brendt
Second my 2004 rodeo reduce power light came on once in awhile if i got out and taped on the throttle body and then started the engine it was good for awhile. what that did was jar the brushes on the throttle actuator motor. every time it came on i just got out and taped on the housing. What i did was remove the motor from the throttle body housing took the motor apart which was very easy where the brushes ride was all black. Took some sand paper cleaned very carefully till all the black was gone. Never came on again 3 years ago. They have a issue with this more than u think several people i told this to and they fixed there reduce power light issue. Easy if Light comes on shut engine off raise the hood tap on the throttle body housing opsite end from where the wire plug in there is a electric motor in this housing then restart engine . If light goes off do the above and clean
Wiggle your wire harness while it's running, it might make a difference. It is probably a broken wire though. Broken wires don't fix themselves with a wiggle. Splice a new one where you find the broken one and be sure to fully insulate it and protect it from rubbing the frame.
