motor pull problem
I'm pulling a motor out of a 98 with 2.5 liter. Pulled the four housing bolts and the 4 inside flywheel bolts as well. I can't separate the motor from the (automatic) transaxle. Is there a trick to doing this? I lifted the motor to clear the pins and lifted the tranny and I can't separate them. Any help appreciated.
Aside from that, if you have all those bolts pulled, they shouldn't be connected by anything other than their alignment pins. Perhaps a bit of wedging would help start their separation? Mine tended to come apart with a bit of flair; maybe a little more encouragement is all it needs.
