CEL at high speed - '99 OB/MT
With late 1990s OB/MT's, is there any known problem with the CEL coming on at high speed, showing misfire on cylinders 1 & 2 (P0301, P0302)? I ask because that happened the other day - 76 mph, 3463 rpm, 8inHG MAP - with a CCR engine under warranty. Wires and coil are within specs. CCR claims this is a known problem that Subaru didn't fix and can be lived with. Sounds awfully fishy to me and my Subie mechanic on a number of levels, but just thought I'd check here to see if anyone had heard of it (I'm asking this on a couple of forums in case you come across it elsewhere). Thanks,
I would have guessed coil or spark plug wires also.
