-September 2024 Special Lease Deals-
2001 Sienna ABS/Trac Off/VSC lights
My wifes car, the ABS, Trac Off, VSC light come on now and stay on. She has to turn off the car and then restart to get them to go away. Any ideas why these three come on and stay on at the same time?
Just like OBD-II, there are diagnostic codes for the ABS system, but without Techstream (Toyota) or proprietary modules for other laptop bases systems, you aren't going to be able to retrieve these. There is a way to get the ABS system to flash the dash light to show the code, however. I'll have to pull up some info from the service manual if you need to know how. There are dozens of ABS codes, pointing you to wheel speed sensors, brake light switch, etc. Did you have some info that prompted you to change the ABS module?
