01 Linconl Ls8 Aftermarket stereo.
luckycaliluckycali Member Posts: 17
I took out the 6disk alpine deck and put in a aftermarket in it. I'm trying to get the factory 5 min play when key is remove does any knw if that's possible to do? I'm trying to find out where I can locate the tack/speed wire and also the dimmer wire? I found a wire that will dim my display but I can't dim it more if I used the rotating light switch for the dashboard.
  • akirbyakirby Member Posts: 8,062
    The accessory delay logic is in the head unit itself using signals from one of the computer modules. You might be able to rig something up with a relay but you'd have to test all of the wires to see how it's wired and used.
  • luckycaliluckycali Member Posts: 17
    Thank you for the respond. Does that apply to the sterring wheel buttons as well?
    No - you'd need a special adapter to get the steering wheel buttons to work with the aftermarket stereo. Just google it and you should find some.
