Seat warmer
applebayapplebay Member Posts: 1
2005 Pontiac Bonneville seat warmer indicator light nor warmer won't work. Any ideas ?
  • Kirstie_HKirstie_H Administrator Posts: 11,254
    This might be a good question for our Answers team:
    http://answers.edmunds.com
    If you post a question there, you can either bookmark the page, or return to the link above and click "my answers profile" to check for feedback.
    MODERATOR /ADMINISTRATOR
    Review your vehicle
  • imidazol97imidazol97 Member Posts: 27,810
    The heaters have identical modules under each seat. Switch them and see if the problem moves to the other seat with the module. If not, it's your resistance wires woven into the backing for the leather seat material. Check resistances and it's usually in the bottom that the circuit is open. Take leather cover off by pulling back to expose the wire that comes up near the back of the seat bottom and start looking. Often there's a burn mark where the hot spot burned in two when the seat was on. Some folks take the seat out of the car (4 bolts) and it's easier to examine. Use solder wick from Radio Shack as a flexible repair material to replace the burned point in the wiring.
