"Temporary Manual Mode" to Save Brakes?
in Subaru
I am the happy owner of a 2013 Impreza 2.0i Premium 5 DR automatic. I usually drive in automatic rather than Manual, but there is an option to use the steering wheel paddles to enter "temporary manual" and downshift or upshift. I have been using this to downshift and slow the car with engine braking as I approach many stops and turns, thinking it would save the brakes.
But, am I saving the brakes at the expense of the transmission or engine or gas mileage? In other words, is this a bad idea?
Thanks for any advice.
Andrew
Andrew
Plus, the primary reason for downshifting a car while slowing is to keep the car in the right gear for the speed (a defensive driving technique) moreso than any benefits derived from not needing to brake. Given that an automatic will keep you/put you in the right ratio on demand, I'm not convinced that there is any prudent reason to use the paddles for downshifting on a regular basis. Ultimately, I doubt you will see any real benefit in terms of brake longevity (unless you mange to do this on a highly regular basis and would otherwise brake frequently) or issues involving wear & tear. Fuel economy should be unaffected in any noticeable fashion as well.
Thanks again.
Andrew
I agree about being in the right gear, though.
Andrew
