Calling Los Angeles-based car shoppers: Have you recently traded in (or plan to trade in) a car with negative equity (i.e. the amount you owe on your auto loan is greater than the car's value)? A reporter would like to speak with you; please reach out to PR@Edmunds.com by 11/6 for details.
gasoline octane requirements
I just bought a new car and the owners manual says
91 octane is required.My son works for this particular dealership and says they routinely use
89 octane.Looking at various car magasines I see that a 10:1 compression ratio calls for premium fuel.My car has a 9.8:1 ratio.If I see no noticeable performance difference will I harm the engine over time using 89 octane.I don't drive in the mountains,tow anything,or drive over 70 mph.
For the most part, the lower octane may cause a spark knock that the knock sensors will pick up. This will cause the computer to retard the timing thus reducing power and eliminating the knock at that time. Mild brief spark knock will generally not hurt anything but heavy continuous knocking will cause damage.
You probably bought the car because you liked the performance among other things. If the engine was designed for high octane, then I say use it or buy something else. The dealership saves money using 89 octane in cars that are at the dealership for a short time.
