Chevrolet Cobalt Audio Questions
I own a 2006 cobalt coupe ls, and i'm planning on putting my stereo system in it... but in order for me to do that i need to replace the stereo with my head unit. does anyone know how to remove the trim without breaking it? or if you need any special keys after the trim is removed? :confuse:
I've had more problems with the gas gauge--it said that I had a 1/4 of a tank and the car would not start. Unfortunately, I had it towed to a chevy dealer and the mech wrote "2 gals of gas = engine run". I felt like an idiot, but they claimed they reset the "IPC" (computer) but it happened again within a week--this time it showed a 1/3 tank. I filled it up completely and now it seems better.. who knows.
I agree with others that the factory stereo is quite good. It is limited principally by the small speakers (small due to the size of the doors and location of glass etc.). Crutchfield has tons of replacement speakers to play with. One option would be to replace the rear speakers, which are larger, with higher quality speakers. And possibly add a power amp to drive the newer speakers (better speakers are sometimes less power efficient, hence the need to place an amp after the head unit, before the speakers).
But I'd keep the head unit, it's probably as good as you'll get.
I know it is a four speaker system with XM, CD with MP3 capability and an AUX-IN, but I can't find any info on the power of the amp and the capability of the speakers.
Thanks in advance.
I have always bought Alpine stereo's with every car/truck that I have owned but there is no reason to anymore with these great standard radio's nowadays.
Ty in advance!
I agree that sticking with the stock audio system is best. On my last car, a 99 Ford Contour, I added an aftermarket head unit and speakers. When I put the stock components back in before trade-in, I realized that they sounded okay. The stock speakers weren't as detailed as the Infinity's, but I could hear that difference only when parked; when driving, the road noise obscured that audio detail. I probably could have improved on that by installing an amp, but wasn't comfortable with adding a power-intensive accessory to an electrical system that wasn't specifically designed for it. I know there are beefed-up batteries and coils that are made for this purpose, but that just makes it even more of an engineering Frankenstein. If I had it to do again, I'd install only the head unit (the stock one was a cassette) and leave everything else alone. My LS is just fine in its stock form.
If no one knows, I'll either call the dealer, or enjoy the factory installed system until the warranty runs out.
I have a 2009 Cobalt.
I don't want to override one preprogrammed radio station with another, I want to simply make that radio space blank-with no radio station there-awaiting for me to program something into it at a future time. I want it as it was in the beginning, never having been preset or programmed at all yet-(with the possible exceptions of my stations already programmed in).
I bought the car used and someone elses stations are already on there. I simply want them removed. How do I do this? Thanks.
If you're wanting to clear the first row, I'd look for a fuse that is the memory power for the radio. Removing that fuse should clear the memory after a period of time.
However, I would think you would have stations of your own for the 6 slots in the mandatory 1 row of presets. But if you don't, the memory, or keep alive fuse, is the one to find. I have a factory service manual but I'd check the glovebox manual first to find that fuse.
Just removing the radio fuse shouldn't do it. There may be a separate circuit supplying power all the time, even when the key is OFF.
I did set back to the first row (1) only so I would not have to see the other preset stations and Rows I do not want. Row 1 is all I have and want currently.
Still, the previous owner's radio stations are still there, even if I am not seeing them and I would still like to find a way of clearing them out.
I did not see in my owner's manual anything about a keep live fuse so I don't know where to look for it or even if that option will work.
I hope there is an answer to this problem. Can I contact the radio manufacturer or car manufacturer and ask them? If so, what would be their contact info?
Turning on the radio itself, everything works just fine. Sounds like normal, and nothing is wrong. I haven't tried out anything in the CD player just yet, though going to do that soon, but I doubt it'll sound different. So far though, it is just when I hook in my iPod.
I've tried two different sets of cables to hook in the iPod, so its not the cable, may just be the port itself. Is there anything I can do about it without having to replace the entire radio? Would rather have a cheap fix if I could, that still sounds decent.
