-September 2024 Special Lease Deals-
Pontiac Bonneville Electrical Problems
My 98 bonneville has frequently been stalling on me. It mostly happens when I first start the car up, or when I put the car in park after driving. But this week it happened to me while I was driving. When I try to restart the car it won't restart, but the weird thing is the windows won't work either. All the other electrical items in my car will work, except the windows. After playing around with the window switches for 5-10 minutes, the second the windows work the car will start. Once the car starts the check gauges light goes off. I have brought the car to my local pontiac dealership three times. The first time they said my battery cables were stripped. A week later it did it again. The second time I brought it in they said it was the pvc valve, but again it stalled. The third time they said they couldn't find anything wrong with it. I'm very frustrated. Anybody have any idea what could be causing this.
Check large fuses in Maxicenter also (relay center on firewall above motor). Remove, wiggle, etc., to ensure contact is good.
There's one by the driver's left foot by the emergency brake in the left kick panel. There is one under the carpet by the driver's door, between the door and the seat. There's on on the passenger side also. I'd start with the one by the emergency brake.
If you have a sunroof, please let me know, because your leak problem could be something else and I can help.
I found all 3 under the hood, one on the battery side, and two on the other side. Please tell if these are the ones
you found under the hood. Also, please help me to find the other 4, two in the trunc and 2 in the cabin I think.
Appriciate you help,
-haro
went to an auto parts store, he checked the circuit breaker for power windows, he said it was fine, then we replaced an accessory relay,, that didnt fix it,,
call dealership they said there is a 10 and 15 amp that could be replaced to solve the problem he didnt have any idea where they went though, front fuse box or back,,,,,
then he said its probably not all these fuses going out at one time it could be a 700.00 body module?? dont know what that is
any way i need some guidance into what i can do on my own, or what might really be the issue here,,,
thank u all so much
I believe I've heard mention of connection on the hot wire needing tightened in a discussion of 000 and up models. I have a Lesabre 03 and I note those in case they happen to my car.
Are you resetting the tires after you've equalize the pressure and are rolling at moderate speeds? There may be something funny with the wheel speed sensors there that also apply to the ABS and Traction Control readings for the computer.
Airbag circuits I'd be afraid of.
The grounds inside the car may be giving trouble causing dashboard oddities. There are ground buses under the carpet at the drivers seat next tot he door and same for passenger. There are connectors that have grounds plug into them to share the ground and they corrode from water getting into that area from getting in and out. There also is aground connection in the A pillar by the parking brake; I've never seen mine.
The keypass module should turn on the security light when you turn the key to on. If you leave it there after about 5 seconds the security light goes off. If the light is flashing when you turn the key, the unit didn't read the right resistance in the key pellet. The car will not crank for 3-4 minutes.
You will have dash lights when you turn the key, but there will be no start ( and no injectors and ignition spark).
Otherwise your unit is probably okay. Sounds like you get the starter cranking.
If you email I can suggest other help if you haven't already found the problem. Email is in profile; click on my name in header to read profile. But PasskeyI isn't it, the way it sounds.
Try jumping the battery with cables from another battery after you check those on the car itself. The extra voltage/amps might make it start telling you there's a problem in a cable or connection at lower ampere supply.
Any suggestion?
awu
brownzfa
A neighbor had a different GM car that had a bad computer. It would run poorly at idle sometimes and roughen above idle and couldn't be driven. Junkyard equivalent computer fixed it. But be sure to diagnose first to avoid wasting money on guesses.
Are you getting fuel? Does fuel pump run. Push the schrader valve on gas line; does fuel squirt out at high pressure? Use cloth over opening to catch spray.
I don't know if your has the panel above the passenger's foot above the hush panel under the glovebox? It may be on the side of the car under the A pillar, i.e.
If it's the standard dash and all the lights are out... have you tried the knob, lever, that changes the brightness of the dash lights. I am probably suggesting something you already have tried. I recall some headlight switches have had trouble heating and charringplastic connectors on the back of the headlight switch and that might affect the dash ligthts.
Does the radio dial light go bright and dim with the dimmer if it works? Or is it out too?
My leSabrs were 93, 98, and 03. So I don't have a model near your year. But I can help fix you up.
The battery itself could be a problem or the cables that connect to the battery and connect to the grounds and other ends of the positive cables could be it. If you have the double cable with one connector on top of the other screwed to the same post those are susceptible to corrosion. Remove them and clean both completely. Look down into the plastic part of the cable. Battery acid has corroded down inside the plastic on some.
You probably already know this but remember to remove the ground cable first and connect it last to prevent arcing from your wrench on the positive.
At the same time the power door locks wouldn't work. This sometimes happened while driving and lasted up to 10 minutes. I rarely if ever happened while sitting in the garage when I first started the car.
I used my service manuals and figured it was a ground problem. There is a ground buss piece where several grounds connect together at the bottom of the A-pillar, beside the emergency brake and under the carpet. I can show pictures if you want. It seems to be sensitive to moisture being in carpet from getting in and out with snow, rain, on feet.
Some people have tried stomping to vibrate the connection which is buried under the plastic edging and had the connection work. I learned about this after I joined another forum--I had figured out it was a ground but didn't know where.
I another discussion there is discussion about DICs not working. Is your car an electronic display speedometer? It might be those pesty circuit boards. Email to my address listed by clicking on my name at the top of this post to see my profile. Read it all to find my email. I'll send you info that may or may not help. Your problem with gauges/DIC could also be the ground. I can post pictures here if you wish.
Ebay seller of electrical reman stuff
What can I do?
Wires look good.
Plug ins look good and secure.
Bulb sockets are ok shape. Little rust not much.
Thank you for your time.
You probably have a blower control module problem. It is an automatic temp control car? This is where the fellow is pointing on top of the housing for the incoming air for the blower motor which is to the right of his hand. The module is held in by two bolts; it gets cooled by the air flow.
Access is easier if you take out one or two bolts holding the relay center above the blower unit and raise it. I don't know if he did that in the picture.
You can double check by supplying power directly to the blower leads from the battery with a fused power wire and keeping it grounded to be sure the blower motor is working.
The module is available from ADvance auto, junk yards-different ones for different carso-be careful, and gmpartsdirect.com, rockauto.com, and another one to price shop online. It's under AC/heating, electrical, usually.
Troubleshoot it first to be sure it's the problem. They usually fail stuck on and drain the battery running the blower motor after car is turned off. Also fail where they vary with temperature how they act with the blower motor running sort of at very odd speeds for the setting on the dash control...
