Ford Aerostar Heat & AC
in Ford
My fiance owns a 1994 ford Aerostar 2wldrive 3.0, it was leaking coolant to the heater core so he bipased it but now the heat doesnt work and now its startign to get cold out.. my question is where is the heater core behind the firewall?? Im thinking about replacingit it wont cost to much but i need to know where it is...
brokecar2me.. :sick: :lemon:
Look over the Chiltons for details.
LPN
The van is running a normal temp and some water comes out of radiator fill when reving the engine. I checked the temp of the lines going to the heater core out of the thermostat housing and was getting 130 degrees coming out, at the tee to the rear heater it dropped to 115, then was 90 at the heater control valve but no water coming out of the lines that hook up to the heater control valve feeding the heater core. Could the water pump/impellar be bad but still cool the engine ok or possibly the previously mentioned valve that feeds to the lower radiator hose be bad. Auto Zone did not have any pics or secription of this valve either.
I need to get the heater going so my kids dont freeze. Any suggestions would be appreciated.
I have a rig that the heat quit working in. I've had the thermostat replaced and the radiator flushed. The AC does work. A few months ago the van started "ticking" when the vehicle is turned off. Like I drive 25 miles to work with no heat or air being used and when I take my smoke break two hours later the vehicle with "tick". Last week, the van got hot, which was a first. I noticed there was a leak on or around the heater control valve. I haven't done anything yet, except finding this site.
My thoughts are to replace the heater control valve. I have no diagram to do so, it'd be nice to confirm that it was hooked up correctly.
My question is what can be my problem with the lack of heat? Does a bad heater control valve cause the heat not to come out? Could my heater core be bad?
Information/opinions are appreciated. I just want my rig to have normal heat. I worry that some "other" damage could be done my continuing to drive it as it is.
No matter where the heater core is located, follow the same basic steps. First, remove the cable from the negative battery terminal. Wait until the engine has cooled down, then drain the antifreeze from the radiator. Save the antifreeze if it's not old so you can put it back into the radiator after replacing the Ford heater core. Remove the heater hoses at the firewall but leave the engine-side connections attached.
Hope it may work.
