-September 2024 Special Lease Deals-
Honda Civic GX Fueling Problems
I recently bought a 99 civic gx on ebay and when I tried to fill it, it would not take any cng. I thought it might be because it had difficulty going into park, I had the cable repaired at s.f. honda but they said it would need a new regulator for over $700 installed and they are not even sure if this would fix the problem, they said it may need a new tank for several thousand $$$$. Has anyone experienced a problem where no gas would go in at a fast fill station. Also, the repair guys seemed clueless even though it was the dealership, is there any place in nor cal that works on these issues with mechanics that are experienced?
Can you return the car and get your money back?
You are right the mechanics sound clueless.
What happens when you try to fast fill it.
Does it sound like any gas is entering the car at all?
Maybe the refueling receptacle isn't letting any cng into the tank. The pressure regulator would NOT effect filling the tank.
Yes replacement CNG tanks are very expensive!
Sorry I couldn't be more help. Please let us know here on the forum what happens!
http://www.baytechcorp.com/
maybe because it had a fill valve leak...
Could it be that simple?
R. Bohl
415-751-3447
rhbohl@aol.com
San Francisco/Danville
The car had been "certified" recently by a qualified CNG installer, and another leak detected and repaired, but the slight odor persists.
Please open manual tank valve.
It's placed directly on your CNG tank.
I don't know what exactly Honda has, but
there is an examples of manual tank valves:
http://www.tulsagastech.com/formman.html (pic. 5, 13, 26)
http://www.autogasitalia.it/db/prodotto.asp?lan=eng&id=923
http://www.teleflexgfi.com/cng_manual_cylinder_valve.php
http://www.valvulashoffmann.com/prod01_eng.html
707-422-1660
Fairfield CA 94533
or Google: Daytech Fairfield
Honda has increased the frequency that they recommend the filter to be changed over the years as they've examined older fleet vehicles. Look at it this way: It's an inexpensive part that prevents major damage to your engine.
I buy the filter's from Majestic Honda online for $87 each, and then the 10k mile service with the oil change is about $125.
Bud Raymond.
Filter A (near rear of car) is to be drained every 10,000 and replaced every 30,000 miles. I paid $51.72 at the parts counter.
The service manual indicates to replace the O rings every time filter A is drained but the dealer in Monrovia did not have the rings in stock.
I think that the service sales staff do not understand the GX maintenance schedule. I was offered some other services at 15,000 (with my free engine oil change) but the service advisor did not know anything about the filter replacement schedule.
1. Tank is already full
2. Fuel station pressure problem
3. Manual shut off valve under the car in off position
Replacing the tank would definately not do anything for you except lighten up your wallet. Even if the tank valve was malfunctioning it would still allow a fill up
Murphy
Does anyone know what the cost of the high pressure CNG filter is on the 2006 GX, or what the part number is? Hopefully it is not outrageous!
similarly, this is why you'll find a much 'fuller' tank at max pressure if you use a slower-filling device ... fast fills actually generate heat in the tank as the gas particles collide at higher velocities, reducing the number of good stuff (moles) you can squeeze in at max pressure.
i believe the owner's manual states that the gas gauge takes temp into acct when determining how much you have left (aka, when that light does come on, it should be temperature independant) and you should be able to make it the same distance (more/less) regardless of temperature.
if someone knows more, or any part of my understanding is incorrect, please chime in!
epi
The manual is available from Helm , or you can find them on e-bay for about $20.
The temp sensor is about $35 and the pressure sensor is about $250. Small chance that it is a pcm or software problem.
This is on the high pressure side and not a do it yourself project. You are looking at $250 - $ 500 , most of that is labor.
Sometimes honda will cover repairs out of warranty on things that just should not fail under normal use. It doesn't hurt to ask at the service dept.
I'm going to try replace low pressure fuel filter when it comes to replacing the filter but I'm looking for more info before I try to attempt it. need your help.
Did any of you guys tried to replace the filter for newer Honda GX 06 or 07 ?
For the 06 and 07 low pressure filter is located in the back of the car not like last model it was located in the front of the car next to engin.
Here is good web site for great price for honda parts
www.thehondapartsstore.com
16905-S1G-003 ELEMENT ASSY., CNG FILTER $22.65
Vic
Now, to the repair. Honda has a policy of not reinstalling a CNG tank even if they were just going to remove it to replace a solenoid. But, if you find a CNG-knowledgeable machanic, he can probably pull the tank, change the solenoid and put it back in for a few hundred bucks.
Or even find a used regulator?
I'm a chemical and materials engineer and can't believe that any competent engineer would bury the valve solenoid *inside* a fiberglass wrapped tank.
As far as a shorting solenoid causing any explosions, not going to happen as the solenoid is in a pure methane atmosphere... need both CNG and oxygen in the right amounts to cause explosion hazard.
It is a problem that should be taken care of, but my sense is that Honda got their money out of us and are leaving us out to dry.
At this point, my only idea is to sell the car for parts. Does anyone have any ideas about where to sell such a car so I can net more than $500 from the used car shyster down the block?
Solutions:
1) I was able to reach under the car and turn off the emergency shutoff valve and then start the car until it stalled again, and then return the shutoff valve back to on and everything would run fine. This solution worked for about a year.
2) Wait for about 30-40 minutes and turn the key to ACC to see if the fuel gauge starts to climb from empty. (The car starts just before the towing company arrives.)
3) Dealership recommends removing the negative battery terminal for 15 seconds to reset the system. (Haven't tried this yet but I will buy an extra 10mm wrench for the glovebox.)
