-September 2024 Special Lease Deals-
Pontiac Montana Electrical Issues
The interior lights will "not" go off when I shut the doors. The only way I can turn them off is to use the over-ride switch on the overhead console. I did check the BCM PRGRM and it is set on program three (three tones). I there a multi function module that needs replaced?
Take off you rear right tail light assembly.
Remove the PC Board from the light housing.
Use care to not break the plastick clips when remoing the PC board.
Disconnect the PC Baord that holds the bulbs from the wiring connector.
Look at the connector on the PC Board. The middle one is black, corroded and the black plastic is partially melted.
Look at the connector end.
The connector is melted around that plug location and the connector is also black and corroded.
Use a small flat blade screw driver to clean the pin connection on the PC Board side.
Go to the junk yard and cut out a couple of these wire harnesses for the plug. Cut off about 6" of wire with the plug. Use a wire crimp tool to replace the plug. Be sure to wire it exactly as the one you remove.
If you forget how, look at the left side light.
I believe this is seen only on the rear right due to the exhausts location on that side and the fact that GM trys to save a nicle by using too small of a ground connector causing it to over heat.
Good Luck.
Sorry for the wordy post. Any help would be appreciated.
Mike
Jack Hirneisen
Colorado
Here are some possibilities: when the original motor burned out, the window switch circuit board up-function might have fried. I'll check the circuit board for any visual signs damage. Another possibility is the blue wire is broken....which is going to be tough to find.
I'm trying to find a wiring diagram, but no luck so far.
Has anyone had similar problems with this vehicle (or Olds Sillouette or Chevy Lumina APV)?
Any suggestions?
Many thanks,
Jack Hirneisen
Jack in Colorado
Then on the right margin it will ask; "Choose Car Year". Enter the year, i.e. 1999.
It will then come back asking for model, etc.
I entered mine; a 1999 Pontiac Montana 3.4 Litre V-6.
I got 3 Recalls and 148 TSBs. Click on: http://www.alldatadiy.com/TSB/49/994902gn.html
to see my results. That's about all you get for free. You will need to subscribe to their service for more detailed info, or find a friend that subscribes.
Jack in Colorado
3 problems. 1. when I first bought it the gas gauge would go to full and as i drove it a few blocks it would fall to empty. At Cdn Tire they told me to put an additive (Valvoline) in the gas tank, now the gauge went to full and stayed there, no more movement. the vehicle had been sitting idle since last fall.
2. the rear door refuses to open with either the flicker or the hard key, it clicks but won't open.
3. Also the clock doesn't lit up and the volume control doesn't operate as it should.
Any ideas???
Paul
Jack in Colorado
Thanks for the response. Briefly, yesterday the led lit up on my radio, after I switched off the ignition and restarted, it wouldn't lit up again. As far as the rear latch and the gas gauge are concerned, when we buy vehicles in Ontario, they have to be safetied and these two items are part of the package so I'll go back to the dealer I bought it from for correction. I was hoping to find someone who had first hand knowledge of these two problems to save time, hope the mechanic knows.
Paul
Gets stuck often to the point that we don't use that side anymore.
Any suggestions?
Have you heard anything back?
Jack in Colorado
Paul
The junk yard had them from a wreck at half the price, but so many are failing I thought it was worth the extra $$$.
Jack in Colorado.
It goes dead, we replace it and everything works for a while. It's been about once a year we wind up replacing it. This time, the battery was under warranty, so at least that.
If it were the alternator, I think we'd know. If there's a ground somewhere, you'd think if it sat idle for a few days, it'd go dead.
It happens all at once and when it does, it won't hold a charge.
Am I missing anything?
The Montana has a fuse box AND a Circuit Breaker Box,,,it might be "tripped".
To reset, see the owners manual.
Jack
Does anyone know what to do about the wipers? It is becoming a big problem.
Jack in Colorado
Could be two different problems..
1. simply a tail light bulb is burned out and causing a false reading in the computer or a power feedback.
2. but probably it's a short in the tail light fixture (pig-tail). The pig-tail supplier used a plastic that could not withstand the heat, so the black power wire is shorting out on one or more wires (in the pig-tail). You will need to remove the tail light fixture, cut out the defective pig-tail (smell the burned plastic, and view the melted female recepticals!!??), install the new pig-tail, be sure to use a di-electric grease in the new socket, install new bulbs and test.
This problem has been reported on the NHTSA web-site, but GM refuses to do the recall.
Jack
I think this is the correct place to post this.
Regards
The passenger side seat heater does not work
the passenger side UNLOCK doesnt work.. you can Lock, but the switch doesnt work to Unlock..
All fuses look good, any thoughts??
