-September 2024 Special Lease Deals-
Mazda MPV Starting/Stalling Problems
While driving through the neighborhood. My mpv just died. It was though someone reached down and turned the key off. No warning, weird noise or anything. Checked the fuel system. Seems to be OK. I'm getting gas through the fuel filter when the ignition is turned on. I am getting no spark off of the plugs. I traced it back to the distributor and I am not getting any spark out of the distributor coils either. I am getting voltages into the distributor 12Vdc (battery voltage) and 5Vdc (maybe a control of some sort) but no voltage out of the distributor. Has anyone had any similar problems like this. It would be nice to know exactly what to check to determine if it is in fact the distributor, before I drop $300.00 (non-refundable) on it. It definitly isn't working, but I'm not sure if it is the distributor or something that isn't telling it to fire. Please help.
My guess is that the coil went out. I am not familiar with specifics on your engine as I have the 2002 with the Ford engine.
John
John
When they investigate they find the same thing - carbon tracking.
Their explanation is they think the spark plugs must have invisible cracks in the porcelain and maybe there's a whole bad batch. I don't get why it would always be centered around #2 though.
I found one post in an older (now READ ONLY) forum that says both the plugs and the wires need to be replaced at the same time, but my dealer doesn't get why one would affect the other.
The other thing is that the dealer admits he's not sure why this happening and seems to be happy with replacing the plugs and giving me the car back.
Any suggestions on what might be happening here?
-Brian
Has anyone had this happen to them? Is it the O2 sensor, the Cat? or gulp,... the ECU?
-Brian
-Brian
There was a recall for some 2002-2003 MPV's for the PCV hose. If the original owner of your MPV did not have this done you could get it done for free under recall. The recall hose was upgraded not to break down as quickly as the old one. So make sure you get the hose with the AJ511389YB part number...not AJ11389YA.
Actually if done by the dealer could be just as expensive as a coil. You can still go to Autozone and have them check kyour codes. Sometimes the computer will store a faulty code but the CEL will not come on. If you are sure it is the hose you can tell the dealership to go ahead and replace it and save yourself $95 diagnostics. If a hose is ruptured bad enough you will hear a hissing noise from the very back of the engine. A few parts you have to take off to be able to take a good look at it.
The hose is a bit tricky to get to, but you could do it yourself. The hose cost about$70 and labor around another $70... if you have to throw in diagnostics that's a pretty big chunk of coin. Good luck.
-Brian
If the hose has already been replaced under recall, with the old "YA" hose, then I would ask the dealership for some "goodwill", as Mazda is obviously using (used) substandard/poorly designed PCV hoses.
If you have an autozone in your area you can have your codes checked for free.
We just had our lower PCV hose replaced on our 2002 MPV LX. We bought the van used in late '03/early '04 with low mileage, but it is now of course no longer under warranty. We did not get any notification about a recall (although we did have something else replaced as a recall a good while back).
So 2 questions:
1) The shop told us they had to remove the plenham (manifold) gaskets on the engine in order to be able to get to the PCV valve to replace it and so those gaskets were replaced. Is that correct? (If not, I have a major bone to pick with them 'cause it cost more to replace those than the pcv hose)
2) Given how long it has been since the warranty expired, would this repair have been covered? Even if the answer would've been yes, I guess it is too late since I'm sure a Mazda dealership would have had to do the repair as a recall, or?
I'm not an expert, so maybe someone else can chime in with the details. I've never read of anyone having to replace any gaskets to replace the pcv valve or hose. You had both the hose and valve replaced? The PCV hose was initally under a recall in 2002 (?). It was replaced with what some feel was still an inferior hose, which is not currently under recall but has been replaced with a newer redesigned hose, the one that was probably just installed in your van. I'm guessing your 2002 MPV had the PCV hose replaced under recall before you bought it. You can check by calling your local Mazda dealership and giving them you vin number. They can also check on what recalls were done and if any are still required.
I've read a good tech can remove a pcv hose/valve without taking off the intake manifold. But, some dealerships will remove it... guess this was a judgement call that favored the dealership.
Even though your van is out of warranty, any recall work that hasn't already been done... must be done free of charge by the dealership.
Any ideas?
Hard to say which coil is bad, could be more than 1. They aren't cheap to replace at the dealer, not terribly hard to DIY if you search for instructions.
-Brian
I am afraid of an ECU problem as I do not have alot of money to put into this car
any ideas of what i can look to fix to get er back to running and starting again? :sick:
Million Thanks.
It would be a miracle for all 6 coils to fail at the same time. No, your mechanic is not guessing. He is incompetent. Take your MPV somewhere else.
If he did replace #2 coil, he should have asked you if you wanted #1 and #3 replaced since they are in the back of engine as well... would have saved you a lot in labor.
Thanks again
With the back 3 coils (#'s 1-3) you have to take off the intake manifold to get to them... takes about an hour and a half I believe.
thx, BK
