Kia Sedona Steering Wheel Vibration
bluedevilsbluedevils Member Posts: 2,554
I've reviewed all the posts about this issue, but have not seen anyone post a successful resolution. Has your dealer identified the problem and if so, have they been able to fix it? If so, how?
We are going to purchase a 2006 EX this week and I would like to have this issue addressed before delivery. Will drive the van tomorrow and find out if it exhibits the problem.
I have looked all over the excellent kiatechinfo.com website, thru the Tech Times, TSB, Pitsop, etc. sections. I could not find ANY mention of this steering wheel vibration at speed issue. The closest thing was 1 issue that causes a pull / out of alignment problem. I haven't read that article yet to see if it sounds like it could be related to the steering wheel vibration issue.
«1
  • rgochoargochoa Member Posts: 17
    I had a vibration on my 2006 Sedona upon delivery. Dealership balanced tires--problem went away.
  • likellehlikelleh Member Posts: 35
    After all my 2004 issues...took it to the Dealer and got a 2006....almost 10 thousand miles and loving it! Had the fuel pump noise issue around 400 miles but haven't heard it again since 1000 miles and there is a fix for it now. Had the sensor strips replaced under recall but other than that...it's been great! :)
  • redptcredptc Member Posts: 78
    Check KIA FORUMS.COM there is a few vibration problems on its forums for the 2006 sedona.
  • churchmusicguychurchmusicguy Member Posts: 6
    I had the same problem on my 2006 Sedona. It took four visits to the dealership (considering how many people have this problem, it's a mystery how the dealers are so ignorant of it!) before they finally swapped out all the tires and it went away. The tires that come from the factory seem to have a VERY high defect rate.
    What model Sedona do have EX or LX? Just wondering what tires you have.I had trouble with Hankooks.
    Mine were Hankooks, too. If Kia is smart, they'll stop using them.
  • capecoralbillcapecoralbill Member Posts: 51
    I have a 2007 Entourage with 17" Micheleins, same problem, the dealer rebalanced them, they seem a lot better, almost perfect, but there is still some barely perceptable vibration at 70 - 75 mph, it could even be an engine or transmission, or even wind buffeting effect. But dont blame the Hankook tires, cause i had it on the micheliens.
  • azcamperazcamper Member Posts: 5
    I am also having a vibration problem on my new '06 LX Sedona at freeway speeds. Mine feels like it is one or both of the rear tires. I have had it in to the dealer twice and both times my service rep said they re-balanced the tires. He says they are in "perfect" balance now and they test drove it and is OK. I drove it 80 miles on the freeway yesterday and it is still bad. Back end vibrates so bad at certain speeds that the second row seats shake and the shoulder harness belts rattle against the sides. My tires are KUMHO. How did you convince your dealer to replace the tires?
    I just kept taking it back until he got tired of seeing me, I guess. I would suggest you print out a few of these messages and take them with you. Show him that you're not the only person who is having the problem. My tires are HANKOOK, not KUMHO, although I'd guess they're both Korean, based on the names. I'm looking forward to having to replace them with some good ol' American rubber!
    I purchased a 2006 Sedona that had Michlein tires. We too had a vibration. Dealer rebalanced tires and now rides smooth as glass. Perhaps it is time to request a meeting with Kia rep regarding the replacement of the tires. I don't believe the dealership has the authority to do so unless the rep instructs him to do so.
  • volfyvolfy Member Posts: 274
    What speeds are you guys having the vibration problem? Mine are Michelin Energy LX4 and I don't feel anything under 80mph. Van is still new so I try to keep it under 75mph.
    I did some reseach on the Energy LX4 before I took delivery and the reviews weren't all that bad. If they were, I would've driven from the dealership directly to a tire shop. I've done that before with a brand new Nissan Frontier and got the OEMs replaced with a set of performance tires for $150 or so. The tire dealer was happy to take the OEM tires in on trade, because they still had the "hairs" on them, so he could sell them as new tires.
    Anyhow, 235/60R17 is not a very common size. Tirerack.com only shows 5 other tires in this size, none of which looked any better than the Michelin Energy LX4, so I guess I'm gonna stay with them.
    I start having the vibration at about 60 mph and it gets a little better or worse as I increase the speed. It is real bad at 75 mph and not quite as bad at 78. Something else I have noticed, is the problem is worse after I have been driving for awhile, so may be the bad tire/s heat up and get worse.
    After leaving several messages on my service advisor's voice mail with no replies concerning this problem, I contacted KIA customer relations who put me in contact with the dealership service manager. He scheduled me another appointment and took the vehicle to a local tire shop that has better equipment for balancing tires. They did a road force test and determined that two of the wheel/tires were out of spec. The worst of which was the left rear which is the one I suspected to be causing the vibration. They did a "phase match" on all the wheels/tires which brought the readings all within the specification. I test drove it yesterday and it was much improved. I plan a long road trip next week, which should determine if the problem is resolved to my satisfaction.
    I had the dealer rebalance it, the 75 mph vibration seems to have gone away. However, I now have a new problem. At low speeds, pretty much as soon as the car starts moving, it feels rough,lumpy or lurchy, enough to be annoying. It smooths out at higher speeds and after warmed up I don't feel it at lower speeds then either.
    Your right about the dealer being unresponsive or in denial, and he is too far away to make it convenient to keep going in for such a minor, but still annoying problem, this is not how a BRAND NEW WORLD CLASS vehicle should act. Too bad Hyundai may loose its hard built improved reputation over tire, wheel or drivetrain vibration. And yes, my dealer calls me after each service to instruct me to leave excellent ratings when the factory surveys me, but often I dont get the factory survey. I have 17" alloy factory wheels with Michelin tires, my Hyundai Entourage's van build date is June 14 2006.
  • dougvdougv Member Posts: 19
    Greetings Guys and Girls,
    I'd like(!) to join your club. Got a 2006 Sedona LX 2 months ago and have gone through all of your trials. Front end shakes the steering wheel violently at between 75 and 80 mph. Did a rebalance, a force balance, a front end alignment and swapped tires with another good Sedona. Nothing changed. Luv the car, great price and all and driving comfort. Has everyone who posted these wheel problems had them fixed? or what? The dealer thinks he knows the problem. Thinks its the speed controller computer. A Kia engineer is suppose to come to see with his own eyes next week. Can't believe that with all the complaints that I have read here plus many others of course from drivers that don't do the web that Kia does not know what the problem is. Dealer has told me that if all else fails he will give me a new van. With all the Sedonas sold the probablility of me getting two of these in a row seems very remote. I promise if I find out the solution that I will post the cure to this web site!
    Hi, and welcome, I hope you can get rid of that vibration, let us know what happens. As I've said before, mine is very minor, so I can live with it, but i'd rather get it fixed if anyone knew what it was, i dont want to be the guinea pig.
    Good luck
  • leefarmleefarm Member Posts: 14
    we have a 2006 kia sedona ex with the 17 inch michelins.. and we did NOT have any vibration issues . but the lx4 were bald before we got to 35000 miles. since we didn't not want the michelins again i went to look for another tire..thats when i found out there really isn't much of a choice for a 235-60r17 tire.. so after researching i decided to go with 225-60r17 yokohama avid TRZ's just a TINY bit smaller but ok. they are a MUCH better tire than the lx4's. just as smooth as the michelins.. and 10 times better in the rain. we will see how the avid's wear..
  • smillersmiller Member Posts: 32
    My steering wheel and at times the whole van would shake!
    My dealer did all the tests and found both left rims to be out of spec.
    They replaced both left side rims and now the van drives smooth at highway speeds. I should have drove the van at highway speeds before buying but I rented one before and it was very smooth. :)
    Greetings Again,
    Dealer swapped so many front end parts I lost track. Bottom line the vibration is still there. Am past the requirements of the New Mexico Lemon Law and I notified the Dealer that I wanted to exercise it. He said fine. Mean time I had to take the family to So Carolina for a month and they gave me a super loaner, a Dodge Grand Caravan Lx (05). I think I put 6000 miles on it. Ran like I wished the Sedona would. Well I'm back and about to take the Caravan back to the dealer. Anxious to see how this works out. I will post, as promised with the final solution.
    By the way: Test drove two 07 Sedonas in Columbia So. Carolina and both had the wheel vibration one a little less than the other. When we came back from the test we drove into the garage and talked to the service mgr. He answered straight out that they had problems with the Sedonas and it was the rotors that some of them were warped. He said they could be fixed by putting on new rotors or turning on the lathe the old ones. If I didn't have the 06 Sedona I might have taken him up, however I turned him down! Lets see what the NM dealer has to say about tis.
    My Sedona vibration problem was resolved with the "load force" phase matching of the tires/wheels. The ride is acceptable now, but I have rode in smoother vehicles.
    Azcamper,
    Thanks for your post. The dealer sent me out to the Goodyear quickstop? previously for a "load force" phase matching repair. Again it seemed like some help but only very little. Probably just a rare coincidence but the "load force" phase matching is exactly what the KIA factory rep is telling me now is what he wants to repeat on my car but this time done with a "quality European BMW" shop instead of an "inferior" (my word) American shop. Is not a reasonable suggestion as it was already done and also all of the tires and rims were swapped out already with other "good" tires and rims from other "good" Sedonas in stock including the 17" alloy rims. Also the rep has told me that a team of engineers from Korea are on their way to America and that he has requested that they come to my state and examine my car. This drama has now proceeded to the "inconceivable" state. I am getting enough material to write a fantasy novel about this experience. Dealers sales mgr says he reads the Edmonds posts so weighin "other" users. As I said before I have read many complaints here but yours is the first where someone solved the vibration problem. What happened to the rest of you?
    I have a 2007 Entourage with 17" alum wheels, build date June 2006, and I still have vibration at 71-75mph and sometimes on a cool morning at 20-40mph there is a small vibration too. So are we saying this happens on the 16" wheels too?
    My Sedona was an LX and came with the 16" steel rims. He didn't tell me how many other rims he swapped out with but eventually I learned that he had also tried the 17" alloy wheels. Ladies and Gentlemen, I am not trying to create unrest or discontent with people that are happy with their vibrations. However, if you are curious about your Sedona just test drive any other new car out on the highway at 75 to 80 and see just how stable a car can be. I assume the Entourage is mostly the same car as the Sedona as they are the same company and freely exchange parts. Also I have now test driven 4 different Sedona LX's and EX's, at different dealers and they all have have various levels of vibration. So somebody must be happy with their vibrations!
  • lavrishevolavrishevo Member Posts: 312
    Had my 06 Sedona up to a little over 95 MPH today and no vibration. Have not felt any vibrations since I purchased the car 3 months ago. No complaints here van is driving great.
    Thanks lavrishevo for your input. At least I can put one car in the plus column and build some evidence that the car can be fixed.
    No worries. I think something to consider is that most people that write on here or come to the forum to find solutions for problems. All the people who don't have issues usually don't come to the forums so we get a distorted view of how many people really do have issues.
  • fishbreathfishbreath Member Posts: 58
    I just like to stay on top of things. I do have a slight pulseation but that is when I'm on the brakes but not bad. rotors I suspect.
  • lacoydr1lacoydr1 Member Posts: 17
    Hi Azcamper,
    I am new to this forum. I found it while doing a search for the exact problem everyone is describing here. I too have the steering wheel vibration/shake. My 06 has about 6400 miles on it and I have noticed the shake since day 1. I didn't have it looked at until my first oil change at around 3800 miles. The dealer did the old "both front tires were out of balance. We rebalanced them and it's fine now". Well it felt exactly the same when I picked it up. But the dealer is 25 miles from my house and I have a job so I can't spend day afer day at the dealer. I ended up bringing it back down again for what appeared to be belt noise in the engine compartment. I finally realized it was actually because my power steering reservoir was nearly empty. I refilled it and the noise went away but I brought it in anyway as there had to be a leak. I also told the dealer that the vibration issue was never fixed. So, far they have replaced the entire "steering rack" as it was leaking, the two front rotors and did a four wheel balance and alignment twice at the local Town Fair Tire. They called me yesterday and said the vibration is still there but they think it's a bad tire (even though TFT couldn't detect it). They are now awaiting a decision from the Kia Tech Line to replace all four tires. When I asked if they thought this was going to fix the problem, the answer was "I don't know". I highly doubt Kia will authorize a replacement of all 4 tires in the hopes that it may fix the problem. I was wondering why the dealer wouldn't have just tried switching wheels with another 06 Sedona. They've got several "off lease" models sitting in the lot. Anyway, I'll let everyone know how I make out. I am not confident that they will be able to fix the problem.
    Hang in there Lacoydr1,
    As my last post stated engineers from Korea were suppose to be here at the end of July. I now have an update that about 10 of them are coming here to see my 06 Sedona around Aug 13-17. I think this means that they are listening to our posts and other dealers and are about to admit there is a "minor" problem. This is a typical American corporate response and Korea is a subsidery of corporate america. I believe that eventually the problem will be solved. It's like pleading "no contest" in court but not admitting any guilt. But the corporate lawyer way is to drag it out and maybe everyone will go away or maybe accept a lessor solution. As I stated before there is no way they don't know what the problem is. To state a homily "this is not rocket science". Any engineer who claims to be one could solve this in one day. Will keep everyone posted as I stated before. I guess on further reflection the easiest way to get rid of me is to have the Koreans come here and say they can't find the problem and then just give me a buyback. And oh yeh! as I wrote before the dealer swapped out all of my tires and rims with other "good" Sedonas in the lot without a change.
    Hi Dougv,
    Thanks for the speedy response. The dealer just called me before I left work and said that Kia has agreed to replace all four tires with brand new Hankook Optimo H418 - the exact same tires! I am not confident it's a tire problem. It's too random. I would think if it was a tire problem that it wouldn't come and go the further you get down the road. I sure hope your "engineers" figure something out. I'll let you know if the "new" tires make a difference. Also, if your post regarding the engineers decision shows a definite fix then I'll print it off and bring it to the dealer. Good luck to all!
    I have another update on the Korean engineers. They will not be here in Santa Fe until the 20th of Aug. A note of information for what its worth, I was told by a sales person at my dealer that they read all of the posts on Edmunds Forum. Also just where about are you located? We may not have the same dealer but we could have the same KIA tech rep as they cover a very large region. That would be interesting information to me. I think we all have to realize that we are not dealing with technical people here but with their lawyers. I am not normally a paranoid person but I think all of this apparent ignorance on the part of KIA makes the case. Again also, I don't know where you are at but I have qualified several times over for recourse according to New Mexico's Lemon Law. So its not like anyone is doing me a favor by trying to fix my Sedona. I think by now it is KIA's dime that we are working on. I don't know what the dealer stands to lose but he has been great to me including minivan loaners (Dodge Caravans) whenever I needed one. It has been a 5 month journey so far but it will be ended by me one way or the other on the 20th. I'll let everyone know!
  • eggegg Member Posts: 9
    Been reading this forum for a while now. I to have had this vibration problem with my 2006 EX with 16,000 miles on it since it was new. The dealer keeps trying to tell me that it is a tire balance issue. I have had it to two tire shops now and they say that all is fine. It has been to the dealer 4 times and they keep telling me it is fixed. I pick it up and on the way home, Bad vibrations at 70-75 MPH. Do they not test drive it when they are done? I have also had all of the other problems mentioned on this site. 1: Had the front struts replaced first month we had the van because of the bad pull to the left. 2: Have had bad wind noise at 60-75 MPH in high winds(sounds like someone blowing a whistle coming form driver side front). Dealer re-sealed the windshield (after having it to them 4 times for this issue). Have not had a bad wind yet to test it. 3: Had the fuel pump replaced for the noise. 4: Had the air conditioner compressor mount replaced for bad noise. 5: Had problems with the passenger side sliding door not wanting to shut all the way. 5. Had air bag warning light stay on, Dealer said it was something with the seat belt. 6. Poor paint and seems like all you have to do is look at the van wrong and it will get a door ding. Finally told the dealer that he needed to read this forum and talk to kia about the front end vibration. He said he would talk with someone and get back to me. That was two days ago and no word. I am done with this van!! It needs to be fixed now our I need a new van. I think that even if they were to give me a new van, I would drive it straight to a Toyota or Honda dealer and trade it in. Took it on a 3000 mile trip form Missouri, through Kansas, Colorado and New Mexico and had the vibration and whistle the whole trip. Drove me crazy and ruined a good vacation. Please let me know what you find out and I will keep you posted. :lemon: :lemon:
    Hi Guys,
    In response to Dougv, I am located in Western Massachusetts. The dealer is in Northampton (about 25 miles south of me). Still no tires.
    Egg,
    I have had wind noise as well but only when I am going 65 or over and there is strong winds on the highway. Otherwise just the normal wind noise that you get with most vehicles. The lemon law in MA is you have to be without the use of your vehicle for 15 days total for the same problem. Then it's considered a lemon and their would be recourse with Kia. I have only been without mine for 2 days. I've got a long way to go. The problem is I really like the van (minus the vibration). I would have bought a Sienna but I just couldn't afford it. I used to be a staunch Toyota loyalist, then Subaru (because we moved onto a mountain) and then Hyundai because they were cheap and good. In fact I was looking at the Entourage but they weren't doing any deals on them. When I saw the add of the Sedona with $6000 off of MSRP I just couldn't overlook it. Well, you get what you pay for. I'm hoping that Kia actually figures out what the problem is an issues a recall for all Sedonas. We'll just have to wait and see. Good luck to all.
    It looks like the dealer fixed the wind noise, had the windshield re-sealed and seems to have knocked out the problem. Drove it to Kansas city and back and no noise. Now if they can just figure out the front end vibration.
    I just brought mine in today to have all four tires replaced (per Kia's Tech Line guys). I told the service guy when I walked in that this wasn't going to have any effect on the problem. He laughed. They swapped the tires, took a test drive and said "you jinxed it, the problem is still there. So we took the new tires off and put your old ones back on". They have placed another call to the Kia Tech Line. They said they'll call me as soon as Kia figures out what their next steps are going to be. I'll keep you posted.
    Here's my latest update. The dealer called and said Kia Tech Line wants to do the "Road Force Test" at the local dealer's sister Honda dealership. They have a Hunter GSP9700 Wheel Vibration Control System. Again, I'm not convinced this will do anything. They already swapped the tires which didn't make a bit of difference. I'm convinced it's got to be something else like a bad sway bar mount or something. Bottom line, I am going on a two week vacation out of state so I am going to leave the van with them all next week. That should give them enough time to try a few things. Who knows, maybe a Kia rep will come and see it for himself. I'll let you know how I make out when I return.
    Hey guys,
    I just got back from vacation and called the dealer to check on my van. As yoy may remember, I left it with them all last week. Here's the outcome: They finally took my advice and swapped all four tires and wheels with a used Sedona. Lo and behold the problem went away (accorfing to them). They then my tires/wheels on the Hunter "load force test" machine. The results came back that both rear wheels were warped and not repairable by the machine. They have two new wheels on order and they are supposed to arrive on Wednesday, 08/29. Hopefully I'll get the van back tomorrow completely fixed. I'll update you then. :-)
    When you say wheels, do you mean the Steel, or Aluminum or the Rubber tires? Thanks I still have the 73 mph vibration too!
    Dealer has now changed out both front hub assemblies and still have the vibration at about 70-75 mph. I also continue to have a bad pull to the left. They are now going to change out both axles and see if that makes any difference. This will be the 6th time it has been in for this problem. I told dealer if this does not work it is time for a new car. They said that they have nothing left to do after this and would be willing to pursue the issue. It goes in on Thursday for the work, I will let you know how it turns out.
    Gentlemen,
    If you have read my previous posts you should know about where I stand. I will now update you. As stated "several" engineers from Korea and California came to work on my car on Aug 20th. I dropped the car off at 7:30 and left. The dealer called me on the 21st at 3:30 and said the car would be ready in about 45 minutes but he would call. He called me at 5:15 and said it would not be ready tonight but he would call tomorrow. He called on the 22nd at 11:30 and said the car was ready for a test drive. I really did not ask what they had done to the car because I had no way of verifying it anyhow and all I was interested in was the results anyway. Can you guess the results? Vibration was a lot better about 90% good. I considered taking the Sedona on a 2000 mile trip for a shakedown. However I came to my senses. They had had the car for 6 months now and had brought out the A team that had worked for 2 1/2 days and still the vibration was not solved completely. What I was proposing was more of the "gee! howbout we try this" stuff. I finally hit my limit. I told them lets put this behind us and move on I was out of patience. I had not been driving the car and had put only about 650 miles on it. Although it had about 1300 when I gave it its last test drive. Oh! yeah they did do one more thing on the word of the KIA tech rep. They swapped my steel rims and tires for the aluminum alloy 17" and I did one more test. The handling was better but the rims still had no effect on the 75mph vibration. The Service mgr hinted that if I was happy with the new rims that KIA would probably give them to me. Not a bad offer but I wasn't that hard up and I was sick of any vibration, so I turned them down. After I turned the Sedona back in to the dealer he said he would contact KIA about a buyback. He called me a day later and gave me an account of the conversation. The Tech Rep after telling me he would give me a buyback if the last repairs did not work suggested to the dealer that they ask for arbitration. I can't believe the balls of the guy. I had enough evidence four months ago to satisfy the NM Lemon law and gave him all the time he requested and then he wanted arbitration. The dealer turned him down and said no way did he want to do this to me. The dealer then said that KIA would consider some other option if I was open to it. I said I would consider a new car deal of some sort. He said he would contact KIA and get back to me. That was on the 23rd and I'm still waiting. If I don't hear by monday I am just going to wash my hands of it all and give it to my lawyer. Then I will follow up with letters to KIA management and other auto publications. It could just be the local KIA rep or it could be a bigger recall deal and they are just stonewalling it. Either way as I stated before they have to know what the problem is and their way of handling it is to just really Micky Mouse around util we all go away. Again I will post with my final solution for your info.
    Hey,
    Well it's Thursday and the new rear "wheels" (i.e. rims) were installed and they had no effect on resolving the issue. I just talked with the service manager who has been very nice and understanding and he said he was going to bring it over for one last "load force test" with the new rims. After that he will be having his guys deliver the van back to my house (25 miles from the dealership) as he said I have been more than understanding and patient in this situation. I doubt the additional "load force test" will have any effect either based on dougv's latest post. The service manager is waiting to hear back from the Kia Tech Line on the next steps. At the very least if they take my van again I am going to request a loaner vehicle at Kia's expense (as it's not the dealer's fault). Overall I have been very happy with the dealer's response and I am hoping that at some point Kia will take responsibility for the issue and just give people replacement vehicles that don't have the issue. I'll keep you posted.
    Here is the latest with my van. Dealer has now replaced both front axles, and guess what? still has the vibration. It has now ben in 6 times and has had the whole front end replaced now and still no fix. Service manager said he dose not know what else to do. Talked with someone from Kia yesterday and they are now putting it into the Area Reps. hands. Told them that I wanted to use the Lemon Law and that I was well past the qualifications for this. They said that they will see what the Area Rep. has to say and get back to me. Dealer still has the van and I have a loner. Looks like I am in for a fight now. I will keep you posted.
  • jgfrostyjgfrosty Member Posts: 1
    I am not good at describing mechanical problems, but here goes. I have had my Sedona Van for just over 3 years. Had right wheel assembly fly off just over 60,000mi. No help from Kia other than wholesale parts. Dealer no help at all otherwise. Now I have the vibration problems many are talking about. Have had a vibration for 90 plus day. My Kia dealer first went for wheel balance, no help, then replace front end parts from another Sedona van, no change, then replace some bushings ($300 incl labor) and still the vibration continues. They've test driven it numerous times and nothing changes. I can feel it in the gas pedal especially when hitting the pedal for some extra oomph such as going up a hill. The strangest thing though is that the strength of the vibration is not consistent. At times it is not hardly as bad as at other times. Last night for instance I had a trip of 240 miles. The first 190 miles you knew the vibe was there, however I could live with it. Then on a smooth stretch of road it became more violent especially when heading up hills (i'm on cruise). Then after about 15 miles of this, things settled down again and it wasn't as big a bother by any stretch. My service shop has put a lot of time into this, and haven't soaked me any big wads of money. They want to find out the problem too. But I do find that Kia Customer service at head office is useless and does nothing for the consumer. Their field reps. especially in my area show no care whatsoever. If I buy an other Kia it will only because of the guys in the service dept of my dealer. And the Sedona van is as comfortable as it gets. I am a sales rep and spend lots of windshield time every day.
  • clifwclifw Member Posts: 1
    If they ever find the problem please make sure to post. I have the excact same vibration. 65,000 miles. It changes with road types. I have put new tires, had them rebalanced twice. It does not pull but you can feel it in the floor, the wheel, and watch the head rests shake like in a seizure. No idea what to do with this car. :confuse:
    Hi Egg,
    Well the "additional load force test" had no effect on the issue. The Service Manager felt so bad he had his guys deliver the van to my house. They are still waiting to hear back from Kia. One interesting thing I have noticed - I live in the North East. The weather goes from -20 to 98 degrees between winter and summer. I got my van in February and didn't notice an issue until late Spring. Yesterday it was around 72 degrees when I drove home and I noticed the shaking was much improved. This morning it was 45 degrees when I drove to work and again the shaking was much improved. I am going to monitor temperature and intensity of the shaking over the next week. It's supposed to hit 90 degrees by the weekend. I'm also going to let the service manager know so they can relay the info to Kia. Good luck on your lemon replacement fight. :-)
    Hi Lacoydr1,
    Received a call from the dealer's service manager today. The district rep. was in and test drove my van. He to noticed the vibration and after a long meeting with the service manager they have decided to try and change out both the front struts. I told the service manager when he called that had already been done back when they replaced the strut mounts and he seemed unaware. He is now calling the rep back to let him know that the van already has new struts and seeing if they want to try anything else. It is interesting that you mention the cold weather. While looking through my service records the other day, I noticed that over the winter months I did not have it in for service. I related it to not driving long distances and reaching high speeds, but maybe it was something else. I will keep you posted :lemon:
    I swear I don't know why I post to you girls. You gossip like your at a coffee clutch. Firstly what is the service manager or KIA going to do with the information that there is a difference in handling between summer and winter. They are the experts and you are solving your problem for them??? It is so naive to think that KIA does not know what the problem is. I don't think KIA is a bad company because they won't admit this. It is just policy dictated by the lawyers. As far as the lemon law is concerned, it is very specific. If you qualify then you qualify. The purpose of a lemon law is so that consumers don't have to labor and linger unduely long. If you don't want the KIA then tell them. I have gone through everything that you guys are now experiencing, if you have read my posts. I will continue to post until resolution as I promised to do so since so many complained and not one posted after a resolution.
    Hey All,
    Thanks for the updates Egg and dougv. I had called my dealer over a week ago and he said he was talking to the Kia rep the next day. I didn't have the time to call him back until yesterday. I asked what the status was on my problem and the guy who answered put me on hold. He came back a couple of minutes later and said that Kia wanted me to bring the van in for a few days so they could tear it a part. Kia would pay for a rental vehicle while they have my van. I almost wonder if I hadn't called if I would have ever heard back from them. So, either Monday or Tuesday I will be bringing the van in again and they will probably try all of the things they tried on your vans, most likely without resolution. I just hope it's a warm day when they take it out for the test drive. Otherwise they'll think they've fixed it. But if they do give it back to me and say it's fixed (during cold weather) then I'm going to ask what defective part they found that was causing the issue. I am also going to send them an e-mail stating that I won't believe it's fixed until I drive it in hot weather, most likely next summer. That way I'll be covered if the problem rears it's ugly head again later on. I'll keep you posted.
    Hey Guys!
    Good news and bad news? Firstly the good news. KIA has agreed to exchange my 06 for a new 08 Sedona. Don't know yet what the price difference will be yet. I assume it will be just the differences in MSRP. Actually I should be paid for the almost 9 months of "Fill in your own words" that I have been through. The dealer (who has been great through it all) said he would let me know when the 08's are ready to be delivered and I can come in and make my choices on styles and options. The bad news. KIA has said that in exchange for the new Sedona I will have to pay a mileage fee on the use I had of the 06. Now get this! The mileage fee is $.50/mile!!!! This is not bad for me as I had only about 600 miles on the 06 when I brought it in and maybe even less. The dealer told me he would pay this for me. However, if I recall correctly you guys had a lot more miles. Like if you had 6000 miles you would owe them $3000! This is getting close to what you could get from any other dealer on a trade in for any other car. My motivation with so little miles on mine was firstly I did not know how safe it would be to drive it on the highway and secondly, I'm a nice guy and if there was to be an exchange I wanted to give back a car that was almost like it had just been driven off the lot. Sorry, I can't say this about the KIA rep. So, every time they give you back your van and tell you to drive it they are charging you $.50/mile for that privilege. I know this information is not encouraging. The best deal for you is for them to get your vans fixed. However as all the other posts are testament they will spend piles of money doing busy work on your vans and never get down to the real problem. I don't know what else I can do to help you guys. I am not a crusader who will try to get to the bottom of this farce or try to blacken KIA's image. If I get my new 08 Sedona (and it is ok!) I will probably just go away. And I would probably buy another KIA when the need arises! My only consolation would be to have KIA do a Mia Culpa. But as I said before they are not going to plead guilty, only a "no contest" thing. So I will post if I have something new and hang in there!
    lacoydr1,
    Thanks for the information. I have been talking with a Kia representative for about a week and they are reviewing my case for the Lemon law. I just got my van back last week and after all the attempts to fix it, it is actually worse. I have been through this process once before in 1999 we had a lemon GMC Conversion van that was bought back. In that case the dealer was great and fought for us and actually helped us pay our taxes and gave us an additional $2000 to help with the settelment. We only payed $.15/mile at that time. I agree, $.50/mile is not reasonable but excessive. I have 17,000 miles on my van and that will run me $9000!! I have now contacted an attorney to see what my rights are. I will keep you all posted on my resolution.
