-September 2024 Special Lease Deals-
Infiniti G37 Transmission Problems
I just got a new 2010 infiniti g37 sedan ( not sport model ) , maybe it's in my head but i think the car at some times doesn't shift thru 3 rd gear to 4 gear or 4 to 5 , at times it hesitates and rev's up then catches and goes. and sometimes it bog's down then catches. ( auto trans ) this is hard to explain , just curious if any other new g37 owners think they have this issue. thanks , mike D
I moved your post to the G37 iPod/iPhone Integration topic, where it's more likely to be seen. Just click the link to get there.
RD7
please let me know what your dealer say's if you take it back.
reddragon 7 please keep me informed with your results when you contact infiniti usa , i will be doing the same. thks , mike D
I have a '10 G37xS with similar mileage, no problems with the transmission to date.
I noticed you also described your annoyance with the weather updates. I am in the same boat, whoever thought of bringing weather updates to the car is NUTS. This is technology that is beyond useless IMO. I have not tried to disable it however. After the 3 months free XM service, I will just renew the radio service only.
Good luck and hopefully you will zero in on what is happening.
I just got back from the dealership. The tech took a ride with me in my car and agreed to sluggish shifting and acceleration. We took another 2010 g37 demo out and it seemed a little better but had the same issues. They are submitting an inquiry to corporae so the ball is rolling on addressing the issue. Please do the same at your dealership so we can mke this issues more urgent.
The on possible reasoning I got was the adaptive 7-gear tranny may be more tuned to seek better MPG's than acceleration. I hope they didn't tune a 300+ hp engine to better gov't fuel requiremets!!!
In any case, I will keep you up on my progress. Until then, I'm using the manual shifting mode.
Red Dragon 7
I had the same thing on my 2010 Maxima and while I'm not sure you can turn it off, I lived with it until after the 3 month trial was over and didn't renew the navtraffic or navweather with XM; after the 3 months it will not do it anymore, unless you renew everything with XM, I just renewed the radio because I don't need to know what the weather is outside, I can just look out my window for free!!
I have to disagree. Although I am still in break in period for the '10 its right on par with the 08 G35 I had as far as acceleration concerned. I am not exactly following the "break in rules" as I am training her for my driving style, once its broken in she will be exactly where she needs to be. Believe me it takes a lot to be at par with the VQ35HRs in the acceleration dept. Once its fully broken in it should start to edge the VQ35HR, but only just a bit.
I still think you really need to go to a G37 forum with your issues since not every dealer out there knows these cars as well as the guys there. In addition, you have a very tiny audience here. It helps to use multiple sources, this one included. I remember how my dealer knew probably 50% of what I know, I just wanted him to shut up and just let me drive, not that I needed the test drive.
The company is not having any success (after over 35 days working on the car) of fixing this. Has anyone else had any problems with the VDC/off and/or Slip lights? Any suggestions?
Any luck on getting your transmission issue resolved? My '10 G37Sx automatic does the same thing. Has about 1300 miles on it. Didn't notice it initially. Funny thing is, this issue is most noticeable first thing in the morning or after it has sat for a while. Once it has gone through a few cycles, the shifting is smooth as silk. I'm taking it to the dealer tomorrow for its first check up. This is so very frustrating.
Thanks, Bill
I'm sure you all have found this out, but the DS mode helps, and i got the paddle shifters, that eliminates the issue completely because i'm doing the "thinking" and you can blip up and down quicker than the car will do. Clearly they designed this to get better MPH when in D. A friend of mine has a 7 series with an 8speed tranny, his does the same thing.
My point. Since it would seem that the *vast* majority of G37's sold are automatic-transmission cars, you think Infiniti would "get it right." Maybe all
the cars need is a button that disables the "learning mode" feature and lets
the auto transmissions upshifts come at specific, pre-set rpms, that are
based on throttle position.... You know, like in "the old days"......
Infiniti released a TSB reflash for the Transmission Control Module (TCM) to resolve this issue.
(7 SPEED A/T; HARSH 4-3 DOWNSHIFT ON DECELERATION; ITB09-032). The software patch made a world of difference in my Infiniti. The transmission now is much better shifting in all gears as well as Gas mileage improved!!! I don't think any other tranny in this price range compares. Bravo Infiniti Bravo!
I'm happy now and have gained acceptance once again in Infiniti.
HTH
Do you have a 2010 or 2009? with the 7 spd Auto Tranny. I now have 1800 miles on my 2010, the tranny is better after the break in, But NOT a Helluva lot better. In fact, I drive mostly in DS mode, that too is totally different from my 2007 G35X. Man, I miss that car. What a mistake not buying it. "New Is Not Always Better" and in this case, much worse. I brought my G37X in to dealer to apply reflash - ipgrade to Navi system to supposedly work better with iPhone 4 - bluetooth. I really didn't experience what others were mentioning on other forums about the iPhone. I don't use my iPod or iPhone to play music yet....
Please advise the forum on this fantasic news !! Also check MyG37.com !!
what to do?????
Also, the Reflash TSB I beleive refers to the 09 model. The 2010 models are all up to date with ECU and Drivetrain software according to my dealer.
My only other possible complaint is that the steering is too over-compensated for at low speeds. Feels disconnected to me compared to the TSX I just left. Otherwise a fun car.
I traded in my 2000 Nissan Maxima last year for a new honda accord - I couldn't afford the Infiniti at the time.
I absolutely loved my Maxima, it was tuned really well. Sadly it got old.
So are all Infiniti's going to be this way? Does the problem affect both Sedans and Coupes? Any resolution yet? What's the TSB on the tranny, did that solve the 2010 issue?
My honda has a flawed brake design, chews its rear brakes after 12k miles. It seems all the car manufacturers are making crap nowadays, and just don't care. What gives?
Ark1
I also have G37X since July 2010, no problems yet.
After driving around for few days, I've realized that I might have made a wrong decision. I love both the exterior and the interior of the car. The sitting is much more comfortable than the BMW 3's, and it's loaded with convenient features which will cost a lot on a BMW. The engine is powerful, and the acceleration is nice as well. The handling is not as precise as the BMW's, but it's not bad at all. I actually think the BMW's steering is too tight for me at low speed.
However, one thing I don't like about this car is the 7 speed AT transmission, and it made me want to get rid of it and switch back to a BMW. After researching online, I've found out that I'm not alone. I read about the 3rd and 4th gear hunting issue, but my case is even worse. I felt the car is still doing the engine-break when above 65mph. The break is so strong that I can feel something is pulling me back as soon as I release the paddle. I'm not sure what gear it was in when this happened, but it felt like it was either in th 6th gear and didn't shift to the 7th when I get go the paddle, or it was in the 7th and shifted down to the 6th. But none of these assumptions is making sense to me; I wasn't doing overdrive, it shouldn't stay in th 6th gear when above 65mph, and it shouldn't down shift to the 6th from the 7th either. The only thing I know is that it was in D-Mode. Perhaps it was in the 7th gear the whole time when this happened, but it is just too hard for me to believe that was the normal engine-break from the 7th gear. With this kind of behavior, I'm not surprised by its terrible fuel consumption. I drove mostly highways, and with few blocks of city road, the best I made out of this car is 19mpg combine. Believe me, I really tried my BEST. I wish there's a way I can tell what gear it is in when driving in D-Mode, so I can find out what's really going on.
I really need some comments and help from you guys before I take it back to the dealer for checking, so at least I can be confident when I'm there.
Thanks in advance,
Good luck. I hope they get it fixed. The G37 is a very nice car. Enjoy it.
1. Go to MyG37.com forum for more posts about this issue. Advice from members there suggested that after 500-600 miles break -in, drive the car hard, don't hold back. My dealer told me to drive in DS mode as much as possible. I have certainly posted the same complaints since I took possession in July of my 2010 G37X;
2. It appears to me that the tarnny behaves better with the ECU training / learning cycle and I found that after 2500 miles or so, it seemed to perform better. NOT perfect like my old 07 G35X did, but better. The 7 AT is in this car to uptick the MPGs, but Infiniti has elected to sacrifice some performance for mileage. I miss the very responsive throttle [many have complained about that - Not Me], no hesitation, but again, mileage is the consideration here. The ECU / and Drivetrain modules are tuned down to prevent the super sensitive throttle with Neck jerking response that the 07 had, and give better mileage numbers;
3. I just learned from that other forum, that a TSB : ITB10-075 covers 2009-2011 G37 and the 2011 G25 for Hard downshifts from 4 to 3 but members have cited that it seems to correct a lot of the quirkiness in this Tranny. I'm excited - making an appointment asap with my dealer.
I'm in the same boat. I bought my 2011 G37xS limited edition on 12/30/2010 and noticed the problem with the transmission. At first i thought it was a problem with my car. But after doing further research, it seems infiniti really f'd up this time with the AT 7. I had a 2008 G35xS prior to this and i loved the drive so i did not test drive the 2011 before actually buying it.
Good news (i hope): I called my dealer today, there is a TBS out there to for this problem for the 2011 cars. Call you dealer to find out if the TBS applies to your VIN. The TBS was released last thursday (12/30), the same day my dealer delivered the vehicle to me.
I really hope this TBS will address this fockin stupid issue. It is annoying!!!!
I have a heavy foot and have notice violent jerks when going from 60+ mph to a full stop. Have you also experienced the same?
This is really annoying... the '08 definitely drives better in my opinion. I really really really hope the fix works.
I wonder if the lemon law applies to this case... the car certainly does not drive like it should.
I did notice after the TSB has been applied, the acceleration from 60 - 80 is not as responsive.
sigh... if i had to do it all over again... i'd go to the lexus or acura dealership.
what lexus were you considering? also do you think you would have had better luck with the 08 and 5 speed tranny?
Also, I've been considering a "class action lawsuit" against Infiniti for false advertising due to the fact that they assured me the tranny would adjust to my driving after a few thousand miles and it hasn't. The response of my tranny and throttle for a 55,000 car is rediculous!!
Please let me know what you find out and would you suggest I get the update????
Please let me know if anything has helped...
thank you...
I own a 2011 M37 sport with the 7 speed auto that does exactly what everyone else is talking about in here.
Please let me know... thanks
