1988 Chevy Beretta Rough Idle
Does anybody know of a good place to start diagnosing a rough idle on a 1988 Chevy Beretta GT)? Has the 2.8L V6 engine. It also 'hunts" alot with the rpm varying from 450 rpm to as high as 1500 rpm when it surges. I have access to a OTC diagnostic tool, just don't know the best place to start looking. Any help would be appreciated.
a faulty charging system can affect idle in several ways
if the coil is not receiving the proper incoming voltage then it can not properly generate sparkplug voltage consistently
Also if the charging system is malfunctioning it can also affect sensor operation, which can affect pcm functions etc etc. This also can lead to effects in transaxle/transmission function.
hope this helps answer your question
