2014 Jeep Cherokee transmission service message
mkrenesky1111
Member Posts: 3
have new car less than 700 miles/bought 12/31/13. driving tonight an suddenly the transmission service message displays, car loses speed dropping into lower gear. actually may have shut off as I got another series of messages including one telling me to place car in P and restart the car. scary.
also get message that parking brake needs servicing, traction control turned off
anyone heard of this in a Jeep but specifically a 2014 Cherokee Latitude?
sorry. V6 engine
also. attempted to drive off highway I was on. car skipped, like transmission slipping. then seemed to find a gear and drove fine until I slowed down, then slipping again until back up to speed.
Hi. I had same thing happen with power loss this past Monday. I was leaving dealership after third visit in two weeks regarding the check engine light coming on. Traction control turned off, power loss was severe, barely made it back into dealer lot. This is our first Jeep (2014 Cherokee Latitude, small engine). Today I was told that transmission, engine, etc. updates were installed on the system. I am supposed to learn sometime tomorrow whether the 'fix' worked. Regardless, this is not what I expect with a new vehicle (about 10,000 miles when the problems began). Depending on what they tell me, I may well be in the market for another vehicle.
Update on my April 9th commentary: The vehicle was at the dealer for four days. When I picked it up on April 10th the service manager told me that a STAR case had been opened(#S1419000001). They found code P219A in system for fuel ratio imbalance. MAP sensor value was compared to another vehicle. Purge solenoid operation was found ok. O2 sensor values checked ok. Chrysler engineer supervised service tech, and installed updates to reset transmission to factory settings. I have driven vehicle just over 300 miles since the work was completed, and so far it is performing perfectly. I will update again in a month.
Good Morning bruspell,
Sorry to hear you were having trouble with your 2014 Jeep Cherokee Latitude. Glad to hear the dealer was working with STAR to diagnose and repair the vehicle.
Hope your vehicle continues to perform perfectly. If you have future concerns please do not hesitate to contact Jeep directly.
Phone: 1-877-426-5337 or email: www.jeep.com/jeepcares
Lisa
Customer Care
Chrysler Group LLC
So, here's my final update to my 4/10 and 4/15 comments on our issues with the 2014 Cherokee Latitude: On the 18th the warning light again came on. The dealership had promised to 'make us happy' if the problem was not solved after the last effort. We are now driving a 2014 Cherokee Limited. While the solution to the vehicle problem remains elusive, the solution to our issue was more than satisfactory. If you track the case number that I left in my earlier post you will be able to learn what repairs were made.
Sounds like a great resolution and a good dealer.
This is a failure that could cost you your life; I think the NTSB should know about this.
I was looking at a new Charger 3 weeks ago but bought a Altima. Sorry Chrysler but I have to have something dependable.
If the Chrysler group is listening. Help me change my mind. I am looking on trading soon for a bigger SUV. But with this Cherokee I will have to probably take a big loss.
*Dealer recommended battery replacement to ensure computer could work at full capacity, DONE
3 weeks later abnormal shifting reoccurring.
*Dealer recommended transmission valve body kit replacement, DONE
Abnormal shifting occurred again 1½ months later
*Dealer recommended a now available computer update, DONE
Recieved vehicle back with the abnormal shifting still present. Not even at 50,000 miles.
*Dealer recommended new transmission, DONE
3 days later, my vehicle will not drive, will not catch a gear my R light blinks and dash says service transmission. We have not found a fix either but I dont know that there is one.
