-June 2024 Special Lease Deals-
Water building up inside my CR-V on the driver's side ceiling between the window & windshield.
will2001will2001 Member Posts: 2
edited April 2014 in Honda
2001 Honda Civic LX.
I have water building up inside my car on the driver's side ceiling between the window & windshield. The car does not have a sun roof.
Answers
    [Deleted User][Deleted User] Posts: 0
    edited April 2014
    Make sure the rubber gasket seal going all around the door frame is pushed all the way in place. They get loose after being exposed to hot/cold cycles for 13 years (in this case) . The drivers door opens and closes 100 times more than any of the others too, so the gasket gets pulled and pushed around (obviously) so this is most likely the cause.
    Yes I checked the door seal. The wet spot is above the door and about 6 inches before the windshield.
