2003 TrailBlazer. A/C problems
new2580new2580 Member Posts: 1
edited May 2014 in Chevrolet
I have 03 trailblazer that is leaking freon. Seems to be leaking from nut on front metal tube close to radiator. What is that part called?
Answers
  • imidazol97imidazol97 Member Posts: 27,849
    edited May 2014
    The front unit is the condenser. The nut has an o-ring inside. Has the car ever been repaired there with a replacement condenser? Those usually don't leak after the factory puts them together. You have to use a wrench on both sides of the connection to try to tighten if it may have been repair. Most likely needs to be removed and o-ring replaced, lubed, and reconnected to torque. But that needs to be done by someone who can remove the freon catching it, vacuum, and refill.
