suddenly heat guage goes to 1/2 way point after only one three miles
What should I have mechanic look at? I doubt that the sudden change is the radiator or thermostat, one, because it is sudden, and two, because the needle moves up to the half way point too quickly. So, what probably is the cause?
Also, heat blows out vents
Might be the sender or its wiring, or the gauge itself. I agree with you, that's not how a thermostat usually acts.
