93 Toyota Camry hesitation
Im having a little problem with my car and would like to hear if anyone can help. Every now and then my car will hesitate or putter and I think its a problem with the fuel injectors because I can put some Lucas fuel injector cleaner un my tank and it will go away, but only for about 1 month. Sometimes when I'm in the road and it starts happenings I will just floor my car and it stops. So, I'm thinking something lime dirt is getting clogged in my fuel injectors and when I floor the gas it pushes whatever dirt that is in the way away. It's a 93 Toyota camry with 200,000 miles, so I'm thinking about getting a full fuel injector cleanse. I've been reading on the internet about a fuel injector cleanse and sd ome people say it's a waste of money. Can someone please give me some advice on what I should do. I dont wanna get the fuel injector cleanse and waste my money, but I'm willing to spend the money if it will fix the problem.
Answers
Well it imay be the injectors because you said it goes away for 30 days, but it could also be an oxygen sensor, throttle position sensor, or bad plugs/plug wires. I would replace the wires and plugs on a car with 200k before the fuel injection service. Especially if the puttering occurs under low engine load but not during heavy throttle application.
Good Luck!
-Chris
