Ford Focus Electrical Issues
eg_9480eg_9480 Member Posts: 1
edited May 2014 in Ford
There seems to be an issue with the parking lights on the drivers side of my car. The front light the side marker and the taillight lights work when it comes to turning on the left signal, however the parking lights don't come on at all. I was wondering if there is a fuse that could be out, or if it is most likely a wire issue. Please help! :)
  • Most likely a wiring issue. Parking lights and turn signals are independent circuits. I'd trace back starting at the lights and I bet you find a bad connection/broken or cracked wire.
  • wytkidwytkid Member Posts: 4
    I have a 2000 ford focus 2.0 split port engine code (P). Ive had the battery replaced several times and aftet 4-5 days the car won't start like the battery is dead give it a jump start and it fires right up... take it and have a battery tester put on it and the volts are good but the CCA have dropped down in to the double digits... put a brand new battery in it and have all the test ran on it (starter, alternator,etc..) they come back fine... a few days later the problem comes back. Can any help me please...
