How do i get my 93 Accord to restart
cole001cole001 Member Posts: 2
edited June 2014 in Honda
after driving a few miles my accord would begin to stall out, but it would restart.now it won't restart. I replace the distributor the cap rotor button and coil pack,and it still won't start...suggestions???
Answers
  • mrbill1957mrbill1957 Member Posts: 823
    It takes spark, fuel, and compression to run. You need to verify that you have all 3. You could have lost the fuel pump, or even the ignition switch.
    Mrbill
  • cole001cole001 Member Posts: 2
    ty mr bill, im getting spark from all plugs and i have good fule flow the pump works well...compression air flow????...what about the timeing belt?......ignition switch i'll check before i change the timing
  • Instead of guessing which is all any of us can do here, you should take it to a shop that knows what they are doing instead of throwing parts at it. Guessing can get expensive!
