Diesel costs and upkeep?
I am looking at getting a Crew Cab 4x4 (Ford or Chevy) and will be eventually (not now) pulling a horse trailer and living on a ranch.
I'm comparing engines for power and mileage (right now it will just be driven around town and to work). I like what I've read about the new Duramax diesels, but I want to find out what additional costs there will be.
I've read that if you don't do a ton of driving that the diesels aren't worth the extra $$.
Any information on diesels in general, the Duramax, or the Ford Powerstroke, would be appreciated.
Don
Don
1. Maintenance is not cheap! More oil to change. Parts are more expensive. I spent $625 for a new starter. You have two batteries to replace. Fuel injectors can run into the $100s+ EASY, especially for the newer trucks (i.e. the Power Stroke injectors are over $600 EACH and there are eight of them!) You can go longer between rebuilds than gas but rebuilds can run $2000-3000 for a GOOD one.
2. Finding qualified diesel mechanics can be tough, especially in smaller towns. I have had some of the worst diesel mechanics right at the dealership (very little experience). I've had better luck with diesel mechanics that work on big rigs.
3. Fuel is getting to be the price of mid- to premium-grade unleaded. Depending on where you are, diesel can be tough to find, especially in small towns. You have to plan your routes accordingly.
4. Check out TheDieselPage.com. Great site if you own a GM diesel!
As mentioned, if you want torque for towing, diesels are the way to go! If it's just to have a Turbo Diesel, plan on higher maintenance costs! Good luck!
Dave
Wendell
Anyone have any thoughts on that?
Sorry, but I don't get online much anymore. I get between 15-17 city/highway combined. I have heard the Duramax averages around 20 I think. Check out TheDieselPage.com. There is a ton of info about the Duramax there, including a cross-country exhibition drive they did with a HD3500! If I scared you off, that wasn't my intent. I love having a TD! Whether I'm at sea level or 8000 feet elevation, my truck will run fine. I have no trouble crossing Wolfcreek Pass (10,000 feet) in S. Colo doing 65mph! But the above-mentioned specifics really get on my nerves some times. I have seriously contemplated the Duramax, but may go gas for the convenience and the lack of a heavy towing requirement.
Good luck!
Dave
split. Thats a lot more savings than 5 to 6 mpg off of the Diesel. A heck of a lot less maintenance and a 3.5 to 4 qt oil change and $2.50 filters. And still have a new 6.8L V10 to pull with. Its got 310hp and 425lbs ft torque, there's not a whole lot you can't tow. One negative though is you can't swell out your chest and say I have a diesel. I never have compared the two costs together but I bet there less than owning a diesel. Have a great day everyone.
Good idea I never thought of that, another idea would be to dump the Suzuki and ride a bicycle, no gas at all. Mimimal maintenance, no emissions from the bicycle that is maybe a little from the peddler. The old 460 was a great engine I still don't know why they quit using it. Thought for the day is keep Fording.
