91 capri trouble (no heat)
I just bought a 91 capri convert. it is not the turbo, I have very little heat coming through, is this a design flaw or does anyone have any ideas????
First, check and see if someone disconnected the hoses going to the heater core (my suspicion, that the heater core was leaking and someone did not wish to spend the considerably some to fix it, so they by-passed it.).
If the hoses are connected, see if you can feel if the hose are hot going into the heater core (after the car is warmed up). If they are, you have a fan blower problem or a ducting problem (the hot air may be trapped by a closed vent door, or the blower may not be able to blow the hot air down and up.
If the hoses aren't hot, you have either
a) a bad thermostat
b) no water in your engine's radiator (oops!)....which is where the hot water for your heater core comes from.
Doing these things should solve your problem. If your heater hoses were intentionally disconnected, you may have a case for legal action or at least some restititution by the last seller. This is a sneaky lousy thing to do to someone ( of course, maybe the last owner didn't kow either, so there's that to consider before you starting shooting!)
good luck and let us know,
shiftright the host
I had one car that was plugged up with Bar's Leak, the stuff that will clog up a hole is the radiator. It also clogs heater cores, regaurdless of wether they leak or not, and locks thermostats open, creating an always cold engine. What is the temp on the gauge? Should read around 195 F to be considered normal operating temp. If it is low it can also cause poor milage.
If the antifreeze is rusty or brownish in color it is 90% of the time radiator stop leak of some type. If you just got the car it may have been a "dump" job to get it out from under the people. If that cap is in there it is for a reason, and you may end up replacing the radiator. Sometimes the crap will ruin the seals on the water pump too, depends on what type was used, liquid, or powder.
Hopefully it is doesn't need a radiator or anything else major. Any used car I buy gets a tune up, belts hoses, radiator flush, oil change, and all filters changed, right away. It always pays to change these basic things and prevent being stranded on the side of the road.
Hey JG, cut that out. You're gonna put me out of business! :-) Excellent advice, that ounce of prevention, especially if you don't know the service history of the vehicle.
But hopefully the poster will let us know, for our data bank.
