Adding 30 amp 12 volt DC cable to battery or to fuse panel in our 2014 Chevy Equinox?
I have a NEW 2014 Chevy Equinox AWD 1LT and I have a 2 meter Ham Radio which needs a good solid 30 AMP DC power cable straight to the 12 volt battery or should I try to tap in on a spot on the interior DC fuse panel?
I mainly always run the 10 Gauge DC power cables straight to battery but with this Equinox getting a power cable to it looks to be not a easy job. I sure could use some expert opinions and suggestions please?
Also if you can offer some web links with photos with your suggestions or videos that would be great!!!!
I don't know if they are a 25 to 30 AMP spot on the interior DC Fuse panel to tap in on and it be safe or not?
Thank you and hope you all post replies thank you.
N4TUX Boyd
Jonesville, VA.
