Cutting out 1994 ChryslerTown & country Van
gbradcsigbradcsi Member Posts: 3
edited April 2014 in Chrysler
Any ideas why the 1994 Chrysler Town & Country Van intermittendly cuts out while driving, cold or hot. changing the coild di not help, will the engine code list this problem? thanks for any replies.
  • jgmilbergjgmilberg Member Posts: 872
    It could be a bunch of stuff, have the fuel pressure checked, could be a bad pump or clogged fuel filter. If the check engine light is on or has come on in the past, it will show a code. Turn the ignition on and off rapidly 5 times, do not start the van, it will start flashing the CEL, and those are the codes stored by the brain. You can check the autozone web site for service bullitens and trouble code explanations.
    http://www.autozone.com
  • old_guy_in_txold_guy_in_tx Member Posts: 12
    I have a 1994 Dodge Grand Caravan 3.8 I e.g. Mine will cut die when turning corners or sometimes exiting the interstate. Talked to dealer mechanic. He said to clean the Throttle body and injectors. This fixed the problem. The van Does this every couple of years. Have 225,000 miles and still running.. Possibly running several cans of fuel/crab cleaner through it will help...
