Help. VW Jetta stalls.
leeroy10leeroy10 Member Posts: 2
edited July 2014 in Volkswagen
i have a 2000 jetta that stalls after a few mins of driving. it start right away has to sit for anthor five to ten mins then will fire right up. i will drive for anthor 5 to 10 mins then it shut off again then start up after a few mins and so on . i have replaced the fuel pump and also the fuel relay aswell now im at loss any ideas
Answers
  • leeroy10leeroy10 Member Posts: 2
    also replaced the coil pack
  • ClairesClaires Member Posts: 1,222
    Not sure if this is the same problem, but I had a 2002 that just turned itself off a couple of times while driving between 25 and 45 mph.. Each time, I was able to start it up right away, and it ran fine for a few months before it happened again. Replacing the ignition switch seemed to fix it.
