Using the Driver Easy Speak Feature - 2014 Toyota Highlander Limited Long-Term Road Test
edited August 2014 in Toyota
imageUsing the Driver Easy Speak Feature - 2014 Toyota Highlander Limited Long-Term Road Test
The 2014 Toyota Highlander has a special feature called Driver Easy Speak. How well does it work?
  • hybrishybris Member Posts: 365
    edited August 2014
    Daughter is going for a full karate chip but the son is sure that she doesn't have have the range to do much if any damage.
  • wheelmccoywheelmccoy Member Posts: 97
    Speakeasy could let you play bus driver. "First stop, nursery school. Next stop first grade."
  • mahdiggamahdigga Member Posts: 1
    Will work great for the Taxis, that these are used as, in NYC.
