86 Corvette--Jolting Prob..Please Help
My dad's 86 Corvette has started to jolt pretty noticeable when shifting from park to drive. It is idling at about 500-600rpm and a tarns shop could not find anything immediately wrong without tearing apart the whole tarns. They removed the valve body cover and all springs etc are good. Tarns shifts fine during normal use, this is only when going from park to drive and park to reverse although it is not as noticeable when going to reverse. It has also recently begun to idle rough in drive. Car has about 65k on it. Any suggestions would be great. cranny shop estimates about $1000.00 to tear it apart and check it out.
Is it setting codes (Check Engine light) with the rough idle? If not it could be anything. Try a tune-up.
TL
trans crossmember ????? Especially if a youngster
has been whooping on it ?????????
