04 Subaru Forester XT. No power. No engine codes. Overheats. 4500-RPMs = Max.
Hello All,
My 1st post to this forum.
I did a search and this guys description at the head of this thread is remarkably similar to my mystery problem.
- Very close to, if not my problem:
http://www.subaruforester.org/vbulletin/f88/no-codes-engine-wont-put-down-power-turbo-86893/
Here is my story.
Please Help.
-- Condition
- 2004-Forester-XT-2.5-Manual-EJ25
- 123,000 - Just had 120K service at Dealer
- No Engine Codes coming up for any of the following
- It feels like the car is starved for fuel.
Charlie says, "it is running lean" - PINGs at high RPMs
4500 = Max RPMs
FWY- Sugar-House to 215-3300-S = Overheats-Red-Lines
** This is in 4th or 5th - Max speed = 65 MPH
** Pedal 1/2 down to Floor = same effect
** No Power
** It would never make it up Big/Little-Cottonwood2nd gear up a hill = no power
Neutral = Top RPM is 5500 then PINGs
Downhill on the FWY: Max RPM in 4th or 5th = 4500
--- Goals
- Be able to redline the RPMs
- Be able to drive uphill on the Interstate and not overheat
- To have power when going up hill = go above 3500 uphill on FWY
- To have more power than my Prius
- To make it to a ski resort w/out overheating
--- History
All major Srvc before 95K done at Dealer-A
70k
Cruise Ctrl fails when going downhillNever resolved
** Solution = Live with it, i.e. no more cruise ctrl95k
- Independent Mech
Timing Belt
** (Put is incorrectly - discovered at 122k - Blistering - Replaced by Charlie)~100k
- Fuel Lines replaced (gas fumes in the cabin)
Dealer
120k - Mar-2014
- 120k MFG-Srvc at Dealer-B
Radiator Replacement
120k - Trbl Starts
My wife noticed the car was having trbl accelerating
** (She did not inform me at the time)Apr-15: trip to Southern UT
(1st time I really road-test car)Lost a lug nut while in S.UT
See "conditions" Above
121k - May 2014
- Dealer-B inspects (same dealer that did 120k srvc)
- Advises a new turbo-charger
(and possibly a new "flex-pipe" if required)
** Estimates of $2k - $3k
--- 121k - May-July - Independent-Subaru-Only-Mech
Charlie
99% Turbo convinced it is not the problem
** Starts Tbl-shootingRemv & Replc Intake manifold & intercooler & Drop-Pipe (clear from the Turbo) - No restrictions
** Did not make symptoms go away.Turbo - Removed >> Dismantled >> Reassemble
** No smoke
** No noise
** Spun free & no binding restrictions
*** Charlie says not the TurboCharlie Tried All of following: - None of the followed fixed condition:
- Fuel filter swap:
- Fuel pump swap:
- Remv Exhaust & Road-tested:
- Ckd spark plugs - in range
- Remv & Rtrn all Belts & pulleys
- Clean map sensor
- Disconnected waste gate & Road-tested:
Remv & Rplc knock sensor
Timing Belt: Replaced:
- Chk to see if incorrect timing was src of "lurching"
- Not put in correctly by Independent-Mech at 95k
Guides were too close
** Belt was blistering & rollers sticking
** Engine is smoother... but does not fix 4500-RPM-ProbReplace ECU
Minor chg in performance (ECU & New-Timing Belt)
** Better at low RPMs around townBut no fix to the core problem
** Will not accelerate over 4500 RPMs
** 1st notice Overheats if going uphill on FWYDealer-B inspects:
** Take all info from Charlie (above) to Dealer-BTakes into acct. all of C's troublshooting
Concludes that it is either
*** Do A 1stA) Collapsed "Down-Pipe" ($910-P&L by MM)
AND / OR
Rplc Turbo ($2300 P&L by MM)Charlie ran it without the Down-Pipe - It is not the problem
C agrees that Turbo is all that is left
122k: Aug-8-2014: Charlie
- Turbo Replaced
Coolant Sensor Replaced
*** !!!) Did not fix the problemPending: Thur-Aug-21
- Charlie will:
- Fuel-Injectors:
** is going to remove, inspect & maybe clean them
--- Question to the Universe
What is left???
The vehicle was a gem until the 120k service. There is no way of ever knowing if Dealer-B create the situation or not.
** But this point is now irrelevant.
** Some action should be able to fix what is wrong?
*** What is that action?
*** Or do I write it off and get a new car?
It Very hard to give up on it after all this good maintenance and inspection has taken place, and the thing only has 122k on it
At a Dead End.
Please help.
Rick
