Chevy Equinox LTZ Nav/Clock/Radio issues
iluvbubblesiluvbubbles Member Posts: 2
Every time I start my Equinox the clock has reset, the navigation is displayed and sometimes the radio will come on then immediately shut off. What should I do? It is no longer under warranty.
    Still on the original battery? Some auto parts stores will do a load test for free. May not be your problem, but marginal batteries in newer cars can cause weird electical issues, even though the car starts and seems to run fine.
  • iluvbubblesiluvbubbles Member Posts: 2
    I thought it would have been the battery too....So I went to Sears and bought a top of the line replacement and it is still glitching. Thank you
    Well, that's about the limit of my guesses. Sears should have cleaned the terminals when they installed the new battery; I suppose the grounds at the other end of the battery cables could have poor connections. Sometimes people suggest pulling each fuse and reseating them.
    Anyone?
  • unsatisfied33unsatisfied33 Member Posts: 1
     I have a 2012 equinox the xm part of radio hasn't worked right since bought car 6 month ago. The dealer said would to pay get their guy look at it. Does anyone know how correct problem. don't want high price for someone just check wiring. Xm that there has be bad connection in radio. When top collision panel wasn't all way on which tells me they before And thinking got it from dealership fix right. But no more money
