Plymouth Voyager airconditioning probs
trigger7trigger7 Member Posts: 1
edited April 2014 in Plymouth
Our Voyager Expresso has dual zone (front/rear) airconditioning. The rear works fine, but the front, when turned on, works, and then dies back to almost ambient temp within about 20-30 seconds.
It's a 97, 3.8L, that JUST went out of warranty.
A couple of questions...the Chilton doesn't even SHOW the a/c system, claiming EPA and other stupid regs and that only qualified techs should monkey with it. I can only presume this system, despite having two zones, has only a single compressor, right? Would there be two paths for the refrigerant, one to a rear core unit and one to a front? Or would there be a single large core up front in the dash, with just two paths for the chilled air to follow?
Either way, I'm figuring this problem has to do with a vacuum line, the air switching network, or some plenum function. Advice?
David
    gunga64gunga64 Member Posts: 271
    Does anyone know of a plymouth dodge or chrysler that is over 2 years old that didnt have a busted ac. Everyone I know that owns these brands has had a busted ac at least 2 times some 3 and 4. Those idiots cant seem to make a working ac
    alcanalcan Member Posts: 2,550
